Oh and a couple of things. I've added an option to stream the songs directly to your phone or pc, you just need to download SWYH it's perfectly safe and legit.
Once that's installed you'll have to go to line 167 in the default.html and replace the "192.168.1.192" with your IP address, it isn't a nice system by any means for now, I will make it into an option in Musicbee at some point. Also if you forward the port on your router, the replace the IP address with your routers, then you can use it on any computer anywhere!
