Author Topic: Mellow (embedded at bottom)  (Read 8818 times)
Thorbjorn
Description
A clean theatre view to use when embedded at the bottom.
Press the Title to show lyrics and the Artist to show biography.
I have not tested it out that much, but it should work for all skins I think.
Screenshot
Requirements
To use this MusicBee 2.1.4734 or higher is required. Download the latest patched 2.1 version from here:
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
Download here
https://dl.dropbox.com/s/w5u0p0mk3whm8z0/mellow.xml?dl=1
Instructions
Unzip the xml file to the "\MusicBee\Plugins\TheaterMode.Embeded" folder.
dgbx
