Author Topic: Encode / Rip to WMA Lossless?  (Read 3345 times)
jaxtherogue
Is it possible to encode or rip to WMA lossless?
I found MusicBee as I am looking for a tool to sync to Windows Phone 8. This is an amazingly feature rich application.
Last Edit: December 21, 2012, 09:27:33 PM by jaxtherogue
All of the encoding options are under Preferences > File Converters.
There's some excessively high bitrates available for WMA encoding, but it seems lossless is not an option.
jaxtherogue
Yes I saw those and even tried ripping at 100% quality thinking perhaps that actually means lossless, but it doesn't.
Unfortunately, WMA lossless is a closed source Microsoft proprietary format. AFAIK ffmpeg is the only codec that has reverse engineered a decode for these files, but nobody has an encoder solution.
So the short answer is, WMA lossless can only be encoded by Windows.
FLAC is lossless, open source, more widely supported on devices and can be encoded by MB
Version: 3.1.6253
If you're a) desperate for WMA lossless, and b) sufficiently geeky, you can download Windows Media Encoder which looks like it allows for command line batch encoding. It appears to only accept files as input, so you'd still have to rip/encode to a WAV file first, but you could write a batch file/script to automate the process somewhat.
http://www.microsoft.com/en-us/download/details.aspx?id=17792
Probably not worth it really, but it's all I could find.
according to the bass documentation encoding to variable bitrate 100% quality will encode to lossless, and trying now it works fine for me (checked the output file using foobar)
jaxtherogue
Thanks for the response.  I did retest and found that it does indeed write to lossless when quality is set to 100%. I must have messed up my first test.
Is there a way to get MusicBee to recognize lossless WMA files as lossless so I can make use of the "only covert files with a lossless format" option for on-the-fly conversion when syncing to a device? Alternatively is it possible to have it bypass converting ANY format under a certain bitrate (rather than just the selected Convert To format)?
Thanks!
