Author Topic: Dark and Brown Guerila 1.3  (Read 11767 times)
EnduringGuerila
Download My Skins
GitHub (1.2)
Mediafire (1.3)
MusicBee Skin Wiki
I have been using this skin for quite some time with no problems (the way I use it)
The goal:
1. I saw a few bugs with other skins so I fixed them for my needs
2. Be really easy on your eyes ( I do NOT like bright obnoxious colors or white unless they are used sparingly)
3. I like the color brown (what can I say, I'm atypical)
If you find any bugs or have any recommendations to the skin or this post please tell me
SCREENSHOTS! (click to enlarge)
Pending changes:
No found problems, YAY!
Fixed:
-main player "flat" layout has color issues
-album ratings invisible when unrated
+Brown custom buttons
-Strange Purple line when Flat Player is at bottom (disappeared when preparing to fix before fix applied?!)
Last Edit: January 07, 2013, 07:31:23 AM by EnduringGuerila
Music Stats at Last.FM
My MusicBee Skin
My Portable MusicBee Setup (panel layout saved in \MusicBee\AppData\Saved Settings\Layouts)
beeing good
Thanks for this, looks very good.
I use the flat player and I noticed that the spectrum is really hard to see, the first few bar vertically are the same colour as the unused colour (if you know what I mean?).
Having the text centered in the flat player would be my preference as well, but I can add that line manually.
EnduringGuerila
Thank you for the feedback, I don't use the flat player so I hadn't noticed. (adding to list)
Last Edit: December 21, 2012, 03:31:31 PM by EnduringGuerila
My MusicBee Skin
beeing good
Thanks EnduringGuerila, flat player is much better now. Lovely skin!
  • MB Version: 3.6.8849 P
Just downloaded to try.
Looks good from the screen caps
EnduringGuerila
I do hope you enjoy.
Please, I beg that any comments or complaints be brought up.
My MusicBee Skin
Saragis
Hey, I love this skin.
Just wanted to let you know I had this purple line you described in your opening post, but I had it appear with the controls on top (flat layout).
EnduringGuerila
Download My Skins
Mediafire (1.3)
Fixed:
My MusicBee Skin
Thanks for keeping your link up-to-date on the wiki!
