Ah, I had a very hard time finding, and getting those tabs showing. I just found out they were just 'dragged down to invisibility'. Argh...
The color elements that you refer to are shared with tabs in library explorer panel, making it a little difficult to get it perfect for both.
I made a small compromise, and think it's o.k. now.
Thnx for noticing and reporting.
