Author Topic: TouchLite skin  (Read 31523 times)
  • MB Version: 3.6.8849 P
ATTENTION!
This skin has been updated for MusicBee 3 and later.
Compatibility with version 2.5 or earlier is not guaranteed.
A light-toned grey skin with a range of highlight colours, enhanced for touch screens.
Originally starting life as a request (by joebanana) for a touch screen version of MetroColours (Light)
Based on lnminente's MetroColours (Light) skin and now with a touch of hiccup's Zen Hive mixed in.
TouchLite
Blue
Othe Colours
Updates
January 9, 2018:
  • MusicBee 3.1 changes incorporated;
  • added images for high DPI screens;
  • playerbar reworked to include larger volume bar;
  • themed No Artwork and Unknown Artist images updated;
  • icons updated.
Updated:March 2, 2014
  • Minor change to remove some red borders made visible by MB2.3 changes
Updated:January 20, 2014
  • Changed icons;
  • Changed to a light border;
  • Compact player and Mini-player changes incorporated;
Updated:December 16, 2012
  • All lnminente's standard colours finished
Updated:December 13, 2012
  • Minor change to track text handling and use of space when player bar is stretched with large fonts;
  • Pink version added;
Downloads
All skins are in one folder: Download from Skins section of MusicBee Add-ons here.
Installation information, and more, can be found on the wiki
As always, any mistakes or problems, please let me know.
Last Edit: January 09, 2018, 11:25:38 AM by Bee-liever
lnminente
Havokdan
It's my skin Default!!!!!!!!!!!!! Many Thanks, dark version in future?
Havokdan
I meant totally dark...but ok, great skins!!!!!! ;D
It's in the works. Watch the other thread that lnminente provided a link to.
joebanana
It looks awesome, can't wait to try it tonight.
Many thanks!!
joebanana
Huh... doesn't work for me... am I missing something?
Do you have "clear now playing list and current playing track on restart" enabled?
No player buttons will show if there are no tracks to play
joebanana
Indeed. Shoing up fine now.
However, what about the Now Playing text? I have it set to a large font so it's cropped.
Any way you can enlarge the size of this text box?
I've enlarged the text box, but it still won't go beyond 28pt (Segoe UI, Bold) without problems. I think it's to do with how Steven has the SkinCreator calculate space for the text.
Have made a request for Steven to look at the font problem, will update as soon as solution is known.
Last Edit: December 16, 2012, 04:18:08 AM by Bee-liever
For a short time when first loaded, the update files had a naming error.
If you downloaded the updates with the extra spaces in the title:
TouchLite - Cyan or Touchlite - Pink
You will need to manually rename these too:
TouchLite-Cyan or Touchlite-Pink
otherwise they won't be over-written by future updates (my bad  :-[ )
Last Edit: December 13, 2012, 04:15:26 AM by Bee-liever
Green added
All colours finished and file updated
See first post for details
