Author Topic: Frames in the Dark [updated 10/12]  (Read 19048 times)
Greb
Download
Updated 8/12. Added lyrics version, small frames version, perfomer and progress bar version.
Updated 9/12. Added plaques version.
Updated 10/12. Added plaques helvetica version, album tracks can be clicked.
Link:  http://filebeam.com/deb809a7f0586ad4171490981da0c10d
How to install
Unzip in the TheaterMode.List folder.
If you wanna use the 'Negotiate Free' font version, you should install this font. The font is inside the zip file. The 'Arial' font version only uses arial, so no need to install any font.
Other Theater Modes
http://getmusicbee.com/forum/index.php?topic=8096.0
http://getmusicbee.com/forum/index.php?topic=6264.0
Images
Normal version --------------------------------------
With arial font [looks worse, but you don't need to install any font] -------
Plaques version ----------------------------------------
Lyrics version --------------------------------------
Small covers version --------------------------------------
Progress Bar version --------------------------------------
Performer version  --------------------------------------
Clock version [not uploaded yet] -----------------------------------
Last Edit: December 10, 2012, 07:16:27 PM by Greb
Minimalist and simplistic.
Very nicely done!!
Any chance of getting lyrics in there?  Either instead of the artist info panel, or centered under the track info and above the play/pause control.  If it's not possible, or if it's too much work, just let me know - I'll understand.
Thanks for the work as it is.
  • MB Version: 3.6.8849 P
I think this has just become my favourite Theater Mode yet!
Don't know what inspires these great ideas Greb, but I like them.
This is a first from me:
Saragis
I love the look but the images aren't showing for me. I put them in the Images folder under TheatherMode.list.
I can imagine how great they would look from the screenshots, but not from my screen of lower resolution. Same with your Book Lovers work: I can only get a feel. No plan of support for lower resolution?
make sure you are using the latest 2.1 beta:
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
jistme
Wow, very impressive creations (again).
Thnx!
Greb
Thanks for the comments!  :)
Saragis, it's likely you don't have the last version, as Steven said.
phred, there's now a version with lyrics instead of bio.
redwing, the small cover version should look well with lower resolutions.
Thanks, Greb! But I'm afraid to report that three small cover versions are still too big except the wood frame negotiate one.
Greb
Damn! I must have overwritten the good ones.  >:(
Well, I'll change them again some moment this weekend.
izakpolman
Thanks for your great job, but I always can't use it cos it's a shame I'm still using a 1024x768 resolution monitor.  Would it be able to modify the xml myself to fit these lovely theater mode? I use Notepad++ but I am completely dumbed which figures I need to modify except font size which is so obvious.
Now that I see it, I think your implementation of replacing the artist bio with the lyrics is much better than my suggestion of adding the lyrics to the center panel.  This keeps the simple look of the original.  I think my way would've lost that look and it would've become cluttered.
Thanks for creating and modifying this masterpiece!!!
Greb
Thanks again!  :)
By the way, new version uploaded.
PS redwing, small covers version not fixed yet.
Panaoz
hello , great theatre mode. how can I choose the colour I want and remain the same ?
Greb
I'm afraid there's no way to do it. I'd suggest to make a thread in the wishlist forum if you want this implemented.
By the way, link updated.
