Author Topic: MetroTouch  (Read 37556 times)
  • MB Version: 3.6.8849 P
how i change yellow to blue/red/green?
you can't. It's a bitmap skin and can't be edited after compiling.
lnminente's original skin uses a pale yellow, I have deepened it slightly to compensate for the loss of the light top and the increased use of the highlight colour. I don't want to mess to much with the original skin.
Havokdan
beeing good
Minor update and MetroTouch-Pink added
See Reply #13
Green added
All colours finished and link updated
See Reply #13 for details
Adson
The download link seems to be broken.
"(Errorcode: ssl_error_rx_record_too_long)"
A.
Adson
... using "http" instead of "https" works fine  :)
A.
Link fixed (thanks Adson)
currently updating both "touch" skins.
Time permitting they should be up by the weekend
updated version posted
Last Edit: January 17, 2014, 12:05:28 PM by Bee-liever
lnminente
Nice changes, i like a lot result of using a dark background for player controls :)
will have a modified version up soon, to fix the red borders on scroll bars now visible with latest 2.3 update
Update to fix red borders posted
Reply #13 has the download link
Update for MB 2.4
*** colour names have been changed ***
see Reply #13 for details
My apologies to the early downloaders, there was a mistake with the colouring of the check tick in the files  :-[
Corrected files have been re-upped.
see Reply #13 for links
