Author Topic: Old posters and Codex [UPDATED]  (Read 16680 times)
Greb
Download
http://filebeam.com/0b52318f6599619da871ed0ac9df5835
Instructions
Extract de zip file in the TheaterMode folder.
Install the fonts you're gonna use [fonts used in each theater mode are showed in the title, they're inclued in the zip file].
Be aware that you need the very last version of MusicBee! [at this moment]
Credit background
Codex: http://bblegend.deviantart.com/
Images
Last Edit: November 29, 2012, 07:31:08 PM by Greb
beeing good
That's amazing Greb, thanks so much!
beeing good
Even more amazing  8)
I have a problem when I first enter theatre mode though, it changes the size of the window but the contents don't fit properly. If I drag the edge of the window just a little bit it all auto-fits properly.
thats a bug which i hope is fixed now - i will post a link later
beeing good
  • MB Version: 3.6.8849 P
Another great one Greb! Really suits the classical genre well.
Morrowind3
Is there any chance I can have the lyrics where the artist information would be so i can have both the album information and lyrics open at the same time?
You might want to send Greb an email as he hasn't been active in the forum since June of 2013.  Click on his name in the 'author' column of the post just above yours and you'll see his profile.  There's an email address listed.
Open the xml file, search for "ArtistInfo", and replace it with "Lyrics".
