Instructions:
[1] Download and install the sizer appIt allows you to size any window to an exact size.
This is NOT strictly necessary, you can resize the window manually, but getting a exact size is slightly annoying. So up to you.
http://www.brianapps.net/sizer/[2] Download the zip file and extract in the TheaterMode.List folder.http://filebeam.com/9d89f03b8e93da40f94c9fd6295397a1The theater mode is called 'BeeCloud 1440x590'.
[3] No fonts [4] When using the Theater Mode..... you should resize the window
exactly to 1440x590. You can use the Sizer app for it.
Credit for the Background: Some guy in SoundCloud...
Images
