Author Topic: Compact Theater Mode II: A Car Player  (Read 9030 times)
Greb
Instructions:
[1] Download and install the sizer app
http://www.brianapps.net/sizer/
It allows you to size any window to an exact size.
[2] Download the zip file and extract in the TheaterMode.List folder.
http://filebeam.com/99d1f85446c9527eea6168f8241faa38
The theater mode is calle 'Compact Player Car 900x270'
[3] Install the font that comes inside the zip folder
[4] When using the Theater Mode..
... you should resize the window exactly to 900x270. Use the Sizer app for it.
Images
Last Edit: November 19, 2012, 08:19:54 AM by Greb
beeing good
That looks amazing Greb, thanks so much!
SimonBRT
pretty amazed that this is possible,  nice!
  • MB Version: 3.6.8830 P
Looks really good!
Interesting and novel approach to skinning the entire player.
