Author Topic: Wing-ated skin  (Read 38499 times)
  • MB Version: 3.6.8849 P
Updated
refer to first post
Updated
refer to first post for details
Hey, what took you so long to update this? ;)
Thanks for the cute new icons and all the improvements! But something isn't right with player rating.
That's with MB default font, if that helps.
8.1 is only just released  ;)
thanks for the pick-up on the ratings, tested on larger fonts because of the clipping problem there, then forgot to check all OK with defaults  ::)
file in link has been updated
Yes, it's fixed. Thanks a lot!
Aha! Then maybe this should be renamed Wing-ate-oned? ::)
minor update
see first post for details
Maleko12
I'm getting a "no data received" error when I click on the download button.
host-a.net is updating its servers again.  :(
download link in first post has been changed to mediafire
2.3 release version posted
2.4 release version posted
2.4 release version update
Froob
Thanks for your continued work on this skin, it's my favorite.
Another update for the 2.4 release
Wow, and your very first post on the forum!
Thank you, Froob.  Your support is greatly appreciated  :)
Updated for 3.0
see first post for important updating information and download link
MB3 release candidate update.
See first post for link.
