Author Topic: Last.fm Similar Artists/Tracks  (Read 68770 times)
Stockinger
OK what am I doing wrong?
I downloaded the v3 plugin and when I try to enable it an error pops up:
Could not load file or assembly file:///C:\Program Files (x86)\MusicBee\Plugins\mb_LastFMRecommendationsPlugin.dll or one of its dependencies. Operation is not supported. (Execption from (it cuts off here)
Same thing happens for Addtional Tagging Tools  (Exception from HRESULT: 0x80131515)
and the v3 last.fm stats & web browser plugins as well      (Exception from HRESULT: (cuts off here)
same here
Maybe a silly question, but are you running MusicBee 3.0?
assuming you guys are using the MBv3 version of this plugin
http://www.mediafire.com/download/dg2o1e9wnoky6ad/mb_LastFmRecommendationsPlugin_%28for_MB_V3%29.zip
then the next most likely thing is the plugin is probably blocked. In windows explorer, right click on the file/ Unblock
EffenBlue
Yep, latest version.
Yeah, those plugins were blocked. Thanks.
for musicbee 3 only
i have made a change so the Last.fm recommendations panel is now accessed from the Services node in the lest navigator and shows in the entire main panel
you will need the very latest MB3 version:
Beaker
Love this.. Great job..
Any chance you can increase the number of similar artists & similar tracks.
Thanks
Beaker
I take the no reply as a not going to happen..
holuschi
Thank you for the nice plugin. I often use it and found out, that it cannot find artist names with "&" e.g. Belle & Sebastian.
berkua
I am using Musicbee 3, and I can't find how to implement the bottom panel like I used to have. I am attaching a photo.
Please let me know how I can get this back, because this panel is where the last.fm recommendations were, and other tabs that I liked to use.
Thanks!
That used to be supported until v2.5 but no longer supported from v3 on as MB's web browser feature is now separated to a plugin. Instead you get web links from context menu in now playing tab that opens up the link in web browser tab (if you have installed the web browser plugin) or in your default web browser (without the plugin).
barlet
Somehow this plugin stopped working today. Anyone has similar experience? Plugin got corrupted somehow and downloading again solved the problem
Last Edit: September 08, 2017, 12:02:16 PM by barlet
vorward
Will this funtion ever come back to MusicBee?
I would love to see the Recommendations all the time in a PANEL and not only in a special TAB.
Marco Cevoli
I'm resurrecting this old topic, because I'd like to know if you can indeed have the Last.fm related artist information on the Now Playing page/tab. This way we would have a view very similar to https://roonlabs.com/
Jhag
Where can i find the Tracks and Artist Panel in Musicbee? Or can it be shown in another way? Tried the Panel settings, right click: nothing. Maybe i am to blind to see. I really like to use this incredible feature. The plugin is installedand activated, Musicbee Version 3.3.7165 P.
Could someone help, please? Thanks in advance!
Ralf
Have your read #39? :-)
