Hello there,
I just discovered following problem: when I use MusicBee's integrated file explorer, it shows my only a music album, when I select the album folder.
For example:
When I select in the file explorer following directory "
..\Music\2012\02\Abbey_ov_Thelema-A_Fragment_ov_the_Great_Work", then MusicBee shows the album in the main panel. So far, so good.
But when I select "
..\Music\2012", it shows me only an empty main panel. Would be could, if MusicBee would show me ALL albums within the selected directory.
I hope, you understand, what I am trying to tell you
Kind regards,
Legion
