Author Topic: Last.fm Stats  (Read 79240 times)
tomiork
Okay there's something I don't get...I just installed this plugin for Musicbee 3.0 but where can I found it? I don't have any new tab...
https://i.gyazo.com/dbb8075f5b4ce755ec66a9241c38a883.png
its only available in the Now Playing Bar which is an element that needs to be included in the Panel Layout.
at some point i will make it available as a node in Services
rimfir
I don't use LastFM either but I would like to see something like this for the Music Library as well. Any chance that will happen?
for musicbee 3 only
i have made a change so the Last.fm stats is now accessed from the Services node in the lest navigator and shows in the entire main panel
http://www.mediafire.com/download/mvb48tr92ed1vc6/mb_LastFmStatsPlugin%28for_MB_V3%29.zip
you will need the very latest MB3 version:
Mephisto
for musicbee 3 only
Thanks a lot for doing that with the two Last.fm plugins.
superstar19
for musicbee 3 only
Not sure what I'm doing wrong, but I've copied and installed the files in both zip files above, and I'm still not finding the stats in the Navigator.  Can anyone post an image of how this is supposed to look in MB3?
<EDIT> NEVERMIND!  I didn't have services turned on.  Everything's all set. Looks and runs great.
Last Edit: January 30, 2016, 06:31:31 AM by superstar19
  • MB Version: 3.6.8849 P
@ superstar19
You did put the extracted mb_LastFmStatsPlugin.dll in the Plugins sub-folder?
Just saw your edit - glad you got it working :)
murve33
Not sure if this is an issue with the stats plugin or related to the last.fm issues mentioned above, but the column for "3 Months" is displaying my Overall stats.  This seems to be the only time period with an issue (Overall, 12, 6, 1 month all seem to be displaying correctly).   I first noticed this about 2 months ago, but didn't post anything about it due to the other issues.  Now I'm not so sure if this is related.  I'm using the latest 2.5 release.  Anybody else having same issue and is it with the plugin or caused by last.fm?
I have this problem as well. It wasn't a big deal to me when last.fm was using their old site, but now that they updated I never go to last.fm and just use the MusicBee Last.fm stats plugin.
I'm running 2.5.5447 and just reinstalled the plugin. The problem still persists.
Tinidazone
I have created a plugin that displays playcount statistics from last.fm (similar to the foo_silk plugin). When installed the plugin creates a new tab in the "Playing Track" panel (viewable via the Now Playing node or as a separate tab configured via the Panel Layout button by the search box). It works with MusicBee 2 or above
it can show the top 20/50/100 playcounts over 12 Months; 6 Months; 3 Months; 1 Month; 1 Week for your:
- albums
- artists
- tracks
right click on the panel to change the settings
Installation
for MusicBee version 3.0+:
unzip the plugin: http://www.mediafire.com/file/3td2dmt2hd6vdk1/mb_LastFmStatsPlugin.zip/file
- copy the files to the Plugins sub-folder of MusicBee
Thank you, Steven. The plug works smooth as butter on 2020 April. on Bee vers. 3.3.7367  (by the way could we rename MB version to reflect year and month) it is waaaaaaay more convening.
I wear shades 😎 cuz you're just too bright 🔆
SonicRings
I've never had much luck in using this. It worked the first few times I installed it last year, then hasn't worked again until just last month. It no longer works again. I'm not sure what the problem is. Doesn't matter how many items I set it to, 20, 50 or 100, it just looks like this:
Any help?
Any help?
Works here.  Try a different skin.  Probably the default skin is the best bet for testing.
Anything in Help->Support->View Error Log?
Last Edit: April 21, 2021, 06:12:07 PM by frankz
SonicRings
Any help?
I'm using Absolute Zero, which is the very first skin. Which one is the default?
Nothing in error log. Latest entries are a bunch of "4/20/2021 4:22:59 AM - D:\EVERYTHING\[FLAC]\:Thread was being aborted." going back to April 3rd.
EDIT: Just got this in my error log after posting this:
4/21/2021 1:28:00 PM - 10.0.16299.0 - 3.4.7764.37422P - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: Invoke or BeginInvoke cannot be called on a control until the window handle has been created.
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at System.Windows.Forms.Control.Invoke(Delegate method)
   at MusicBeePlugin.Plugin.ReceiveNotification(String sourceFileUrl, NotificationType type)
   at #=z_aDAVc7sMkwkYxQETg==.#=zwpPhZHyK7qbx()
Last Edit: April 21, 2021, 06:37:37 PM by SonicRings
MusicBee3 is the default.
Steven will have to weigh in on whether the error is relevant.
SonicRings
I changed it to MusicBee3 and the plugin worked. I then changed the skin back to Absolute Zero and it's still working. I'm guessing this is what happened last time it worked: I must have changed the skin to something else and then back, after which the plugin worked briefly.
krissasaur
This isn't working for me on 3.5.8447.
