Author Topic: HDCD decoding  (Read 56822 times)
superstar19
As for the 24-bit ripping, I still have all my HDCD discs, but I don't have a ton of motivation to go back and re-rip them @ 24 bits (my collection includes just about everything the Grateful Dead have released on CD).
Since posting this, I have discovered that CUEtools will do the "24-bit" HDCD decoding to already ripped HDCD encoded FLAC files so you don't necessarily have to pull out your actual CDs if you've already ripped 'em once.
you can do the same when ripping with musicbee
superstar19
Oh wow, thanks.  Didn't realize that.  I'll have to give that a try.
AaronM
Is there an updated version of this plugin? I keep getting errors when trying to import it.
I'm on version 3.3.7367 (Windows, not the Store version)
What are you trying to import? Please read the installation/use instructions in the first post
try using the non-store version of musicbee
djony
I have the same problem too that HDCD plugin will not work anymore in Windows 10 20H2. Perhaps some issue with Visual C runtime that this plugin was compiled long time ago with older runtime.
captain_paranoia
Just to clarify for the couple of people who are struggling to install this plugin (me included..)
It DOES NOT install via the Preferences/Plugins/Add Plugin dialogue.
(that was my problem: installing on a new PC, and over-familiarity of that dialogue, and not RTFM...)
RTFM on the first page:
1. Unzip HDCD.zip to put HDCD.dll into the Plugins folder
2. Go to Preferences/Player
3. Press the 'Equaliser & DSP' button
4. Tick the 'HDCD Decoder' in the 'DSP Plugins' section of the dialogue
HDCD tracks will now trigger the HDCD plugin to expand to 20bits
djony
Still can't work and I have tried manually put the dll into the plugins directory. From edit preferences and then plugins, this plugin will not show unless the dll name is renamed to mb_hdcd.dll and the status is disabled because it can't be initialized
put hdcd.dll in the plugins folder
on starting MB, tick HDCD in the equaliser & dsp dialog to activate it
iandrew
The HDCD indication is not available when the wave bar option is used for the progress bar. Hope this can be fixed!
jimmanningjr
Good Morning Steven,
I have been using  MusicBee for over a decade now. I was one of the people who requested this HDCD plug in.
Every system I've had I have installed MusicBee and this plug in. Took some work but I always got this plug in to work.
UNTIL NOW! I have followed this forum and followed all advice concerning installing and using MusicBee and this HDCD plug in.
I have a brand new TrigKey S3 14gigs ram 500gigs storage with Windows 11 pro.....
Any suggestions?
The first time I had this problem ..I downloaded a Patched version of MB, and that did the trick...
Perhaps a similar fix is required
You didn't say what version of MB you are using.  The 3.5 RC3 full versions are available here: https://getmusicbee.com/forum/index.php?topic=36464.msg208192#msg208192
There are patched versions of MusicBee uploaded about weekly: https://getmusicbee.com/patches/MusicBee35_Patched.zip
If you have the "Store" version of MusicBee it cannot be patched.
Adding to sveakul's comment... any new features, bug fixes, and changes in one patch are included in new patches and full version releases.
jimmanningjr
I have been running the 3.5 version of Music bee...also the above patch did not do the trick this time.
