Author Topic: Crimson Creme skin  (Read 51552 times)
jistme
download Crimson Creme 3.x
Note:
The current version is only suited for MusicBee v3.x
Older versions for MB v2.x are still available here:
download Crimson Creme 2.x
Last Edit: June 12, 2022, 07:05:38 PM by phred
jistme
Completely revised now.
No 'greenies' anymore?
Let me know if otherwise.
beeing good
Very nice skin! Looks all good so far :)
jistme
jistme
Updated the 'right drive' version since some proportions seem to have changed a little bit with the latest MusicBee 2.1 update.
grayin
Really liking this skin.  I found one minor item that is still green in the right drive version that I am using.  If you right click on the Now Playing panel and select Search > Text Search a small search box (find) shows up above the now playing list.  The "X" to close this box to the right is green.
When I first installed the skin I also had an issue with white on white text for the playing track in the library list view.  This can now be customized in Music Bee under preferences > Now Playing.  So I just changed it to a suitable red.
Thanks again for making this skin.
Nikkel
I really like this skin except for the red/darkpink color.
jistme
Thnx for the thnx, and congrats on finding this little green eastern egg ;-)
It's fixed now.
This skin seems to be 'a silent force', not much comments, but one of my most downloaded. (and the one I use myself most often)
PS,
I have no clue why some text was white in your setup.
You mean the playing track when in detailed view?
Last Edit: November 02, 2012, 06:23:38 PM by jistme
jistme
I took off my pink glasses, and still couldn't notice any pink really?
I really think it's 'crimson'.
What would be your preferred colour?
grayin
PS,
Yes in the track detail view of the main panel and the now playing list.  I was mainly passing it on in case anyone else sees it.  But now that I think about it maybe it was just something stuck in a setting in my MusicBee.  It won't do it now when I switch skins.
BTW I could see how some monitors could make this look pink, but on my laptop it is definitely a Crimson red color. :)
  • MB Version: 3.6.8849 P
After all this time using this skin, I found a "greenie" when right-clicking a track  :(
and any Command Buttons I have are white-on-white when highlighted. Is that intentional?
Last Edit: December 07, 2012, 11:23:27 AM by Bee-liever
jistme
I'm sorry I made you sad. It's fixed now.
(this greenie doesn't show up in my Windows 'classic' mode)
Nope, that slightly bothers me too.
I would like it to be something like the buttons in the preferences panel, but they have an "id="Controls.Button.Highlight", and I can't find such an entry for the command buttons. (also not to be found through 'dummy skin')
Do you have a cure?
jistme
It concerns those buttons indeed, but I think a "highlight" entry would be needed to cure this small problem.
Just hoover over those buttons, and you see what we mean.
i'll have a look at it when i next revisit skins but it might be some weeks
