Author Topic: RGBhelper script  (Read 12629 times)
lnminente
I have written a small script for helping with the skinning work. Many color pickers stores the color in hexadecimal, but not with the format 123,124,125 to do a fast search or paste it directly between "" in a musicbee skin file.
Pressing Ctrl+Alt+Z it picks and copies the colour under cursor.
When needing more precision run your favourite color picker configuring it autocopying to clipboard with the usual html hex code format. This script watches the clipboard and when finds a string of 7 chars starting with #, converts it to rgb and stores it in the clipboard again with the 123,124,125 format.
Included sources and executable file. I'm not responsible for any damage, try it at your own risk.
RGBhelper
Color picker recommended YS Instant Color Picker: http://youngsmarts.com/index.htm
Autohotkey script:
#SingleInstance, Force
#Persistent
;Some code copied from the help and some from
;http://www.autohotkey.com/community/viewtopic.php?t=45955
Menu, Tray, Icon, RGBhelper.ico
^!z::  ; Control+Alt+Z hotkey.
MouseGetPos, MouseX, MouseY
PixelGetColor, color, %MouseX%, %MouseY%,RGB
clipboard = % hexToRgb(color)
splashTextOn, , ,  % "Colorpicked: " hexToRgb(color) " copied."
Sleep 1500
splashTextOff
return
OnClipboardChange:
StringLen, check, clipboard
If check = 7
StringLeft, check, clipboard, 1
If check = #
StringRight, check, clipboard, 6
clipboard = % hexToRgb(clipboard)
ToolTip % "Hex code converted:" clipboard
Sleep 1000
ToolTip  ; Turn off the tip.
return
rgbToHex(s, d = "") {
   StringSplit, s, s, % d = "" ? "," : d
   SetFormat, Integer, % (f := A_FormatInteger) = "D" ? "H" : f
   h := s1 + 0 . s2 + 0 . s3 + 0
   SetFormat, Integer, %f%
   Return, "#" . RegExReplace(RegExReplace(h, "0x(.)(?=$|0x)", "0$1"), "0x")
hexToRgb(s, d = "") {
   SetFormat, Integer, % (f := A_FormatInteger) = "H" ? "D" : f
   Loop, % StrLen(s := RegExReplace(s, "^(?:0x|#)")) // 2
      c%A_Index% := 0 + (h := "0x" . SubStr(s, A_Index * 2 - 1, 2))
   Return, c1 . (d := d = "" ? "," : d) . c2 . d . c3
CheckHexC(s, d = "") {
   If InStr(s, (d := d = "" ? "," : d))
      e := hexToRgb(rgbToHex(s, d), d) = s
   Else e := rgbToHex(hexToRgb(s)) = (InStr(s, "#") ? "" : "#"
      . RegExReplace(s, "^0x"))
   Return, e
Last Edit: April 11, 2012, 10:44:54 PM by lnminente
jistme
Kyle4G
