Northern LightsCurrent version: 1.2
Download: https://www.dropbox.com/sh/zylzbx57c7raka2/AAA9wJHGy2zHC-QpyinujOFga?dl=0Tested with/optimized for: 1280x1024, 1920x1080
Should work fine for different ratios/resolutions as long as screen height is larger than 920 px
Fonts used: Dotum, Century Gothic, Raavi, Segoe UI
I think all fonts comes installed with Windows 7. Write here if you miss one and I'll see what I can do.
Notes:* Elements does not scale since I had some difficulties getting it just right.
* The rating picture for tracks with a rating of "No stars" might throw you off a little bit at that size - but the stars look great!
* As a Screen Saver on multiple monitors it will default to being shown on monitor 1 with other monitors active. This can be changed in the settings file.
Changelog:2014-12-15
* Updated Dropbox-links
2012-04-06, version 1.2
* Fix: Love icon would show in white for all non-loved tracks using latest version of Theater Mode.
2012-04-03, version 1.1
* Renamed the files so it's easy to add them to the Theater.List-folder.
* Year now uses the field "Year (yyyy)" so year will always be four digits.
Preview:
