Author Topic: Dusk.mod.lnminente  (Read 77697 times)
lnminente
shawnk1019
Just stumbled on this skin, it's now become my default skin, thumbs up on the fine work!
lnminente
Thanks Shawnk1019! The friday revised every single element in player controls and fine tuned all of them. I have ready the small screen version, when finish the normal version will release both ;)
lnminente
Changes in:
-Spectrum colors
-Use of new centering method: PanelMinusProgressBar with latest Skincreator
-Background image of main player, a bit brighter and thinner
-Softed the hided volume knob
-Seekbar adjusted to exactly the point where the cursor clicks.
-Tested with bigger customized fonts. In the pictures i am using Verdana, bold, italic, 9 points.
-Scrollbar colors from panel to dark.
-Changes introduces in small screen version now for normal version too.
Better look with Preferences\Layout\Player controls\Enlarge progress bar height.
Click on image to download each skin:
Sources Duskv2.mod.lnminente120423 (with top workaround)
Last Edit: April 23, 2012, 10:01:42 PM by lnminente
beeing good
Again, some really nice changes!
I have a small issue though. These are the player controls in the previous version:
And these are the controls in this update:
I have it docked to the top of the player, which could be the reason it is like this. The last version you did fixed this from the versions before that but it seems to have reverted back being like this again.
It's not a big deal at all so don't worry if you are busy, I appreciate all your effort already.
lnminente
It's a thing related with the vertical center calculted by PanelMinusProgressBar. Try changing the font or size used in "Preferences\Layout\Player control\Main player\use custom font" to recalculate it. I see it well here on top too.
Last Edit: April 23, 2012, 09:07:34 PM by lnminente
beeing good
Ok thanks, after a lot of adjusting I've found a font and size that works. Kind of annoying though.
Thanks a lot for making the red selection in Artwork View, I was going to suggest that the colour could be changed so you can see what you have selected more clearly. Works really well.
lnminente
Glad you like it ;)
I restarted MB with player bar on top and saw it bad. It seems MB draws one pixel less when is on top you could report it to Steven
I have tried some workarounds, but it would need more work to fix this without tunning the customized font.
Last Edit: April 23, 2012, 09:41:07 PM by lnminente
lnminente
I have redone the highlighted buttons affected for the first line not shown when on top. As a workaround i have cut the first horizontal line in each image.
Last Edit: June 23, 2012, 08:48:10 PM by lnminente
beeing good
That's perfect, thanks so much for your work on this!
lnminente
I have updated the source file DuskBase2.mod.lnminente.xml, now is using variables for an easier modifying by anyone. The appearance is the same, nothing changed. These are the variables introduced:
Selected="129,18,18"
Ground-4="25,25,25"
Ground-3="28,28,28"
Ground-2="30,30,30"
Ground-1="36,36,36"
Ground="38,38,38"
Ground2="43,43,43"
Ground+1="50,50,50"
Ground+2="60,60,60"
Ground+3="70,70,70"
Ground+4="80,80,80"
Ground+5="100,100,100"
Disabled="120,120,120"
Default="180,180,180"
TextGround="210,210,210"
White="255,255,255"
And these are the colours used and their frequency:
4 0,0,255
1 0,255,0
5 10,10,10
2 20,20,20
1 23,23,23
1 23,24,23
20 25,25,25
2 28,28,28
10 30,30,30
2 30,42,58
5 35,35,35
2 36,36,36
59 38,38,38
3 40,40,40
2 44,203,255
2 45,45,45
2 46,46,46
1 49,49,49
12 50,50,50
1 58,175,58
22 60,60,60
1 64,64,64
11 70,70,70
9 80,80,80
1 90,90,90
11 100,100,100
1 101,101,101
2 110,110,110
1 117,153,190
6 120,120,120
1 125,129,161
2 130,130,130
3 131,131,131
1 132,132,132
1 135,135,135
4 140,140,140
1 143,143,143
1 170,170,170
8 180,180,180
1 190,190,190
1 195,195,195
3 200,200,200
43 210,210,210
1 211,211,211
2 220,220,220
1 224,224,201
1 230,230,230
1 232,70,54
1 253,215,99
14 255,0,0
3 255,0,255
14 255,255,255
Last Edit: June 23, 2012, 08:48:59 PM by lnminente
scottjay
Very nice. I have to say that I prefer Dusk's DJ shuffle icon personally
lnminente
(The first version is always getting downloaded instead of the updated ones, now it got 80 downloads, so i going to remove old links)
beeing good
lnminente, I was wondering if you would consider making a version of this one with the player bar text aligned to the centre (horizontally). I've been using the Clarity skin for a while and I think it looks much neater when the text is in the middle rather than aligned to the left.
