Author Topic: Clean LP (Made for 720p and 1080p)  (Read 17705 times)
silasje1
Hey guys,
Ported the old one... was a annoying work of trail and error. So please thank me :)
Download:
http://www.mediafire.com/?dxm25b6ud82ud69
(install the Font too!!)
Tested on diffrent screensizes.
1080p is the best, everything between 720p and 1080p is usuable too
UPDATE:
This version works with latest theatre mode now too.
UPDATE April:
-Fixed some problems with the Time xanchor
-Code is rewritten to work 100% with new theater mode ->http://getmusicbee.com/forum/index.php?topic=6009.msg35756#msg35756
Last Edit: April 23, 2012, 08:44:20 AM by Silas Arentsen (Silasje1)
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
looks good and works as expected but one suggestion would be to allow the album size to fall below 500 otherwise it doesnt scale down well - the album overlaps with the record image
<element type="Picture" x="5" y="200" width="300" height="300" min="250" max="500"  brightness="1.0" ></element>
hopefully that would scale to 500 on your screen but still works when docked to a smaller size
Last Edit: March 23, 2012, 07:20:37 PM by Steven
silasje1
nope... seems to be 300 width always :P i updated the Clean LP file.. forgot to add some things
Dutch Translation
WMP 12 Skin
silasje1
lnminente
Looks nice at 1920x1080, at 1280x800 the artwork a bit big. Thanks for sharing
silasje1
Yeah.. maybe need to code something that allows smaller artwork.
Dutch Translation
WMP 12 Skin
silasje1
Updated for the new theatre mode  ;)
Dutch Translation
WMP 12 Skin
greenday1987
  • Long live OiNK!
Thank. It's a pretty setup. I just have a small issue- the clock is showing an extra ':' so 16:23: for 04:23pm And I  can't work out how to fix it.
RIP OiNK
silasje1
hmm will look into it man. Thanks for the feedback ;)
Dutch Translation
WMP 12 Skin
