Author Topic: MusicBee 2.0  (Read 161203 times)
Installation
1. run the following installer - it includes all changes for Version 2
    http://www.mediafire.com/?m39r2168hifhdwy
the installer will fully replace version 1.4 and keep any settings, plugins or additional customised skins you might have installed - however it will overwrite skin files you have modified of the same name, so you will need to take a copy of those and replace afterwards
2. if you have any Plugins, you can get the .NET4 version of the plugin from the appropriate plugins topic - this step is not mandatory but is recommended
Last Edit: October 14, 2012, 09:03:20 AM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4467.zip
backup:
http://www.mediafire.com/?d72dlt1pdi2tpug
this is an incremental update and includes all changes since 2.0 - unzip and copy all files to your MusicBee program folder
- upgrade to .NET4 (benefits include better performance on lower spec computers)
- enhanced organiser that includes now Video and Audiobook files
- optional  Video Support (playback and file organisation) via a plugin - see the Plugins topic
- upgrade the internal web-browser to the equivalent for Firefox 11 and above
- API enhancements (needed for the new Screen Saver plugin and others to come)
- separate file buffer for WASAPI and ASIO playback when minimise stutter is enabled - this allows the playback buffer to be kept as small as possible without affecting stuttering
- playback of cuesheet files is now continous (so playback is gapless for lossy encoded source album files)
- new "flat layout" for the player controls panel.
    - when enabled a narrower and simplified player control panel is displayed (which gives a cleaner and more modern look)
    - the spectrum visualiser is not available in this layout
    - most skins support this layout well, but some need the skin author to implement this new feature
    - set in the player section of the Layout preferences
- the text search in the main panel now supports using "+" or " or " in order to build a simple condition eg. Rock + Pop searches for tracks with Rock or with Pop in any field
- you can now associate a view (Artwork, Album and Tracks, Track Detail or Default) with a filter eg. you might have a Classical music filter and when using a specific view, you can have specific fields just for the Classical music filter.
- In the artwork layout, holding the Ctrl key down when scrolling the mouse wheel changes the picture size
- clicking a folder node in the Playlists section of the left navigator now shows all tracks from the combined playlists in that folder
- a mute button is now available on the taskbar player
- when entering tag data in the main panel, an auto-complete list now displays
- autoplaylists now allow you to filter out duplicate tracks with the same artist and title but on multiple albums
- autoplaylists now allow you to manually add extra files by drag/dropping files into the playlist. You can already remove files from an auto-playlist using the normal delete mechanism. You can edit the added or removed file list in the auto-playlist definition dialog.
- the Artwork Retrieval Filter (accessed from the Tags(1) preferences screen) now allows you to re-scan and link artwork eg. if you add a new filter you can have MusicBee scan for new artwork matching that filter
- various hotkeys:
    - Send To: Move to Organised Folder
    - Send To: Copy to Organised Folder
    - View: Show Visualiser Full Screen
    - General: Restart MusicBee
- the plugin API has been enhanced to support a new "Theater View" plugin - see http://getmusicbee.com/forum/index.php?topic=6009.0
- video files can now be added to the library without the video plugin being enabled. However the downside is neither duration nor a default picture for the artwork layout will be generated for the video files. Apart from that you can organise and play back the video files using an external player
- some great new skins have been recently added - see http://getmusicbee.com/forum/index.php?board=11.0
- change: default skin has been tweaked
localisation
Swedish file is now available for testing
http://getmusicbee.com/forum/index.php?topic=6015.0
please note the author is looking for someone to maintain this localisation going forward - anyone interested please contact user: Lakrits
Spanish file has been substantially enhanced - contact user alex for any feedback
http://musicbee.niblseed.com/Weekly/Localisation/Spanish1_4.lng
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
http://musicbee.niblseed.com/Weekly/Localisation/new.txt
Last Edit: September 11, 2012, 10:00:08 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4496.zip
backup:
http://www.mediafire.com/?wfzk1b7adjvcwu7
- The Theater Mode plugin has been substantially enhanced and is now included with the MusicBee install package. See http://getmusicbee.com/forum/index.php?topic=6009.0 for details. Also see http://getmusicbee.com/forum/index.php?board=17.0 for some great customisations. Its still a plugin, so can be disabled or removed if not wanted
- windows 7 AeroSnap is now supported for skinned window borders
- the menu bar now displays in the windows glass caption area when window borders are not skinned (except when you have Glass disabled in the windows settings)
- Track Details view now optionally supports grouping. To enable, right click on the main panel column header bar/ Group By/ ...
- you can set the font for the grouping header in the panel layout customisations screen
- column headers in the track browser can be drag/dropped in order to re-arrange them
- you can now specify a folder for Artist pictures (in Tags(1) preferences) - missing pictures are downloaded from the web and cached separately as is the case now
- depending on your setup, you may find the startup time a bit faster
- fixed (what should have been) an infrequent cause of stutter for ASIO and WASAPI
- ASIO output now has a separate file buffer and the playback buffer can now be set as low as 256 samples
- improved column auto-sizing
- various minor GUI improvements
- a lot of bugs have been fixed
localisation
edit:
link updated to fix dialogs not widening for localisations
Last Edit: April 25, 2012, 07:47:14 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4516.zip
backup:
not available
- When the left navigator sidebar is collapsed, it now auto-opens when the mouse is paused on the left window border
- This behavior can be disabled by right click/ Disable Panel Auto-Open
- Additionally when the left panel is collapsed, clicking the location bar auto-opens the left panel (I will be making a change so a ... button displays to enable the location bar text to be edited - for now just right click on the bar to edit the location text)
- The trigger for incrementing Play count and Skip count are now configurable in the Now Playing preferences
- The location for main menu can now be now be configured to display in the windows glass Caption bar, to auto-hide or below the Caption bar. Set in the Layout preferences
- New playcounts are now automatically recovered if MusicBee is terminated without a normal exit
- New Album Duration field
- The taskbar player can be optionally configured to display Artwork only. Set in the Layout preferences
- A maximum picture size for retrieved artwork can be set in the Tags(2) preferences
- The Now Playing Assistant now supports:
  - right click/ Open Playlist
  - option to keep the dialog open after a track has been selected
  - double clicking tracks is now consistent with main player
- When displaying artwork in the track details view, it now displays the artwork on one line only
- The computer section in the left navigator panel now behaves more like windows 7 - double click on the text of a node expands/collapses the node, and single click just updates the main panel with the files in that node (rather than expanding the node as it did before)
- Drag/drop of a folder from windows explorer onto the Playlists header creates a new playlist
- When a MTP device has multiple storage devices, the storage devices are now selectable from the device synch settings panel
- Synching now supports preserving the folder and file path - see http://getmusicbee.com/forum/index.php?topic=6428.msg36971#msg36971
- A number of GUI improvements have been made (computer section now displays more windows 7 like arrows, the scrollbars are partially hidden when there is nothing to scroll)
localisation
edit:
link updated to fix a bug with setting the menu location from the Preferences panel
Last Edit: May 14, 2012, 09:52:01 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4526.zip
backup:
http://www.mediafire.com/?rvyo9rxw2f1ch2x
- library restore function that allows the MusicBee library to be restored to a new drive/ folder location, and is automatically invoked on startup when the saved library path differs from the current library path. You can also remap music folders for files in the library after startup using File/ Advanced/ Remap Music Folders
- Right() function for file naming templates
- various visual GUI improvements - see http://getmusicbee.com/forum/index.php?topic=6398.0
- Auto-DJ status and start/stop is now one of the player Shuffle button states - Shuffle Off/ On/ Auto-DJ
  [some of the recent bitmap skins wont support this feature and will require the skin author to enhance the skin]
- if you have downloaded podcast episodes then startup time should be improved (depending on how many podcasts are downloaded)
- drag/drop of podcast episodes between subscriptions is now supported, along with drag/drop of external podcast files (that may have been downloaded with another app) into a subscription
- flac files now saved the album artist tag to both "ALBUM ARTIST" (existing behavior) + "ALBUMARTIST" (new) - this is to increase compatability with other tagging apps/players
- fix to a few introduced playlist creation bugs
http://www.mediafire.com/?o25i98i0ch4457b
Last Edit: May 23, 2012, 08:38:10 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4538.zip
backup:
http://www.mediafire.com/?g9gsop6siq0cyx1
this is an incremental update and includes all changes since 2.0 (see the first post to install 2.0) - unzip and copy all files to your MusicBee program folder
- support for windows 8
- the main menu can now be displayed as a button in the caption bar (like Firefox). This replaces the menu auto-hide option, and is set in the Layout preferences
- see the New Skin Elements topic for new elements to support this menu button
- synchronised lyrics offset attribute is now supported
- you can now configure the artwork layout so that double click on an album cover plays the album rather than drilling down into the tracks
- in the artwork layout, when you click on text below picture a menu is displayed that allows you to select tracks from the album for playback. This menu has been enhanced so you can also choose an individual track for Queue Next or Queue Last
- auto-playlists have been enhanced:
    - you can filter on similar artists: when the Artist field is selected, a "Similar To" filter option is available. If you leave the artist value field blank, MusicBee will filter on the current playing artist at the time the auto-playlist is generated
    - you can now include various shuffling types to change the distribution of the matching tracks: Random; Higher Rating Preferred; Same/Different Artist
- the library setting to automatically remove dead links has been enhanced to also include checking files for updates (this is default option now anyway, but the purpose is so you can disable this option which can take several minutes to run on large libraries)
- the album auto-tagger now retrieves "mix name" from BeatPort and appends it to the track title
- improved text find functionality for the Now Playing List and Library Explorer
http://www.mediafire.com/?jm32bqpdz2dbdlb
Last Edit: June 16, 2012, 03:17:59 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4551.zip
backup:
http://www.mediafire.com/?bzmah9uhjhno0kb
this is an incremental update and includes all changes since 2.0 (see the first post to install 2.0 if you are using 1.4) - unzip and copy all files to your MusicBee program folder
- tabs can now be docked in the caption bar - set in Preferences/ Layout/ main panel/ tabs orientation
- middle mouse-button click on a locked tab now no longer closes the tab
- the library explorer now remembers the last selected node on restart
- improved starting/ending silence detection and skipping (enabled in the Player preferences)
- album rating can now be edited by clicking it in the Album and Tracks Layout in the main panel
- when the Play button in the Artwork layout is clicked, it can be configured to Play the album tracks only and stop (if not ticked then the Now Playing settings are used). Set in the Artwork layout preferences
- when double clicking on an album picture in the artwork layout, the action can be configured to drill-down and show the album tracks (current behavior) or to play the album
- clicking the text under an album picture already brings up a shortcut menu to play or queue album tracks. The shortcut menu now includes an extra "Find All Albums" command that finds and displays all albums for the selected album artist
- when the artwork layout is displayed, the initial load of the panel should be faster and also when filtering using the text search box
- the text search box should be more responsive now when correcting text already typed in the search box (should be noticeably better for large collections)
- when synching to a device or organising/ sweeping files, you can preserve the original filename by using <Filename> as the last field in a naming template (or ending the template text with "\.")
- the New Tab function now opens a blank tab (it used to automatically load the Music Library node but that can take a few seconds for large collections)
- when rating tracks, MusicBee now updates the Rating tag only (before it was rewriting the entire tag block which meant some tags were tranformed to the MusicBee tag naming conventions)
- the album artist tag for FLAC files is now written as "AlbumArtist" which is more commonly used by other players (previously it was written as "Album Artist")
- includes numerous bug fixes including a (what should have been) rare crash at the end of a crossfade if you had cross-fading enabled
http://www.mediafire.com/?8sd34ta7387792b
Last Edit: June 17, 2012, 08:18:01 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4572.zip
backup:
http://www.mediafire.com/?wujwlavkmcvujje
- You can now save Custom Views eg. you might want a different set of fields and sort order for displaying Classical music. To create a view, click the Panel Layout button to the left of the search box/ Saved Views/ Copy Current View Settings To..
  The view saves the fields displayed, sort order and the relevant panel layout settings (set in the Customise Panel Settings dialog).
  To activate a view just select it by clicking the Panel Layout button
- The track browser being displayed or not displayed is now set and preserved separately for each tab
- The behavior of tabs is changed as follows:
    - Lock Tab now prevents the tab being closed (except by right click/ Close Tab) - before it used to also disable the left navigator panel
    - a new command: "Left Navigator" controls how the left panel is displayed. The settings are: Active; Hidden; Disabled
- Auto-Playlists can now be set to filter based on the current playing track - this applies to the "Is" and "Is Not" conditions when set to "[playing track]"
  eg. set a condition "Genre" "Is" "[playing track]" and if the current playing track has a genre of "Rock" then all tracks with that genre will be included
- Auto-shutdown functionality has been enhanced as follows:
    - new shutdown action to exit MusicBee
    - new trigger for the auto-shutdown to activate at the end of the current track
    - when shutdown is triggered based on a period of time, the remaining time before shutdown displays in the status bar
- The header bar in the artwork layout can be hidden (just a couple of pixels is displayed). Right click on the header bar/ untick "Show Header Bar"
- Fields can now be displayed on the left and right side of the grouping header in the Album and Tracks layout eg. display Album Artist on left side and Year on the right side. Set in the Album and Tracks layout configuration
- New hotkeys:
    View: Show A-Z Jump Bar
    Edit: Copy Tags and Artwork Only
    Edit: Copy Tags, Artwork, Play Counters and Rating
    Edit: Paste Copied Tags
    General: Navigate Back
    General: Navigate Forward
- Artwork can now be fit to the panel width when displayed in the Track Information section of the Now Playing panel. Set in the Now Playing Layout configuration dialog
- File converter now has the option to preserve or reset the play and skip count in the target file
- When grouping by Sort Artist in the Artwork layout, it now uses Sort Album Artist
- When the mini-player is docked to the top of the screen, clicking anywhere in the top 2 pixels toggles play/ pause
- The CD burner functionality has been enhanced to utilise more of the space on a disc than before. Also because of limitations of the windows API being used, a new selector has been added so you can specify the size of the audio CD disc
- Filename character mapping dialog (opened from various places such as the File Organiser), in addition to mappings for invalid filename characters, it now allows two custom character mappings eg. map ";" to " and "
http://www.mediafire.com/?z91jol9shdb0tqe
Last Edit: July 09, 2012, 06:30:52 PM by Steven
http://www.mediafire.com/?t4853jpdtzt4vww
backup:
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4586.zip
if you are using 1.4, see the first post to install 2.0 before installing this update
- Equalisers can now be set to 15-bands, allowing more granularity with the frequency range
- Auto-DJ and auto-playlists can now be set to filter on similar tracks to the current playing track (in addition to filtering on similar artists)
    - in the auto-dj set 'tracks rated by last.fm as more than X % similar'
    - in an auto-playlist choose the Title field, set the criteria to 'Similar To' and the criteria (default) '[Current Track]'
- Custom views can now be assigned to a playlist or a filter (in addition to the existing functionality to assign one of the 3 standard views)
- When opening tracks from windows explorer, the behavior has been tweaked:
    - if there is a tab open with the Now Playing list MB will use that tab (that is already the case with the recent behavior)
    - otherwise, if the current tab is locked then a new tab is opened with the Now Playing list
    - otherwise, it will navigate to the Now Playing list in the current tab (that was the old behavior) - you can click the back button to get back to where it was before
- a new <Date(<field>,"format")> function where format can consist of: yyyy for the year, mmm (or mm, mmmm) for the month and dd or d for the day eg. to get just the year <Date(<Date Added>,"yyyy")>
- Skin element enhancements for skin developers:
    - override the colour of the text displayed with a picture in the Album & Tracks layout
    <element id="Content[AlbumAndTracks].ArtworkText" fg="255,0,0" />
    - override the left offset of the tabs displayed in the Now Playing panel
    <element id="NowPlayingTabsLeftOffset">1</element>
- New Last.fm playlist generator that can generate playlists of your local tracks based on various popularity criteria - see http://getmusicbee.com/forum/index.php?topic=6906.0 for details and the plugin itself
update for the internal browser (equivalent to firefox 13)
http://www.mediafire.com/download.php?x99b43v5rdtc2qx
  - in the folder musicbee is installed, rename folder: xulrunner to xulrunner.old
  - unzip to where MB is installed
  - you should end up with
    c:\program files\musicbee\MusicBee.Gecko.dll
    c:\program files\musicbee\xulrunner\...
http://www.mediafire.com/?98p6h6izsk109a6
Last Edit: August 11, 2012, 11:09:09 AM by Steven
http://www.mediafire.com/?p2bcoc4rud3z77y
backup:
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4612.zip
- functions use a different syntax - the old syntax is still parsed but will be saved with the new syntax
        - before:     <If(<field>="value",a,b)>
        - new syntax: $If(<field>="value",a,b)
    - no longer any restrictions on some parameters having to be a field ie. all function parameters now allow any valid expression
    - new functions:
        - $Trim(expression)
        - $And(expression1,expression2)  eg. $If($And(expression1,expression2),true,false)
        - $Or(expression1,expression2)
        - $Replace(expression,search-for,replace-with)
    - $If accepts not equal to condition: $If(expression1 != expression2,a,b)
    - embed a quote in a string prefix the quote with \ eg. $If(<Custom1> = "[7\"]",true,false)
    - functions should perform faster when comparing against constant numbers, dates and strings
- auto-shutdown function now supports a "fade volume" setting which progressively fades the volume to zero before shutdown
- new hotkey for "Auto-Tag by Track/ Infer Tags from Filename"
- AZ jump bar now supports clicking multiple letters to refine a search (as long as you click the 2nd letter within 3 secs)
- new /Library="path" command line
- a tick field is now selectable as a field to be displayed in the main panel and now playing list
  - in the main panel it is an alternative to using clicking rows to select, the difference being the files stay ticked while you perform other operations
  - when you are ready to perform an action on the ticked fields, right click "Select Ticked Files"
  - you can invert the selected ticks using right click "Invert Ticked Files"
  - click the tick column header to select all/ none
  - in the now playing list the tick box performs the same function as right click/ Skip Track ie. unticked tracks are skipped
- genre categories has an improved editor: Tags(2)/ Edit Categories
- duplicates filter on auto-playlist now chooses the highest quality file by bitrate
- improved performance:
    - startup should be faster when multiple tabs are open - MusicBee only loads the active tab
    - any operations that can affect other tabs should now perform faster as the other tabs are not reloaded until they are opened eg. delete file from the library can affect other tabs that have auto-playlists
- the Library preferences setting to "on startup check for updated files" is now split from "and remove dead links"
- Winamp output plugins are now supported (loaded in the Player preferences panel)
- sub-folders (in addition to the music file folder itself) can now be included when artwork is scanned - Preferences/ Tags(1)/ Artwork Retrieval Filter/ tick "include sub-folders"
- (for skin developers) new skin element "ScrollbarWidthAdj" to adjust the width of the scrollbar
- mini-player now minimises when clicking on the taskbar and not displayed in the taskbar when docked to the top/bottom of a screen
[i decided to go back from firefox 14 version as it causes MusicBee to freeze on some computers, but if you already have it installed and it causes no problems then no need to apply this older version]
http://www.mediafire.com/?28paeq5j21hxyjm
Last Edit: August 17, 2012, 06:32:59 AM by Steven
http://www.mediafire.com/?5xktqnrjaep6t5k
backup:
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4628.zip
this is the last planned 2.0 incremental release with just bug fixes being done before the final 2.0 release
- the "Rescan Artwork" function in Tags(1)/ Artwork/ artwork retrieval filter has been improved and a couple of bugs fixed. This function enables MusicBee to search for and link new artwork based on the filter criteria you set
- a HDCD decoder plugin is now available - see http://getmusicbee.com/forum/index.php?topic=7197.0
- the Opus music file format is now supported
- large auto-playlists should now load faster in many cases
- you can now highlight the playing track with a different text colour - see the Now Playing/ Playback preferences
- the A-Z jump bar has been changed back to its original behavior ie. clicking a letter now always searches just for that letter rather than aggregating into a word search. You can enable multi-character searches by right clicking on the A-z bar/ Enable multi-character searches
  - i decided to go back from firefox 14 version are it causes MusicBee to freeze on some computers
http://www.mediafire.com/?3cz78o2urvdqu38
http://www.mediafire.com/?3cjrix47cxk8aii
backup:
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4636.zip
this is the first release canidate for version 2.0 and contains a number of bug fixes since the last update
update for the internal browser (equivalent to firefox 16)
http://www.mediafire.com/?w02ffiwm7926c2f
localisation
Binary language files - copy to the Localisation folder where MusicBee is installed (not all the files are fully complete for version 2 as yet)
http://musicbee.niblseed.com/Weekly/Localisation/Deutsch.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/French.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/Italiano.lngc   - in progress
http://musicbee.niblseed.com/Weekly/Localisation/Japanese.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/Nederlands.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/Polski.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/Portuguese (BR).lngc   - final
Portuguese (PT) - not updated since 1.4
http://musicbee.niblseed.com/Weekly/Localisation/Russian.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/Simplified Chinese.lngc   - final
http://musicbee.niblseed.com/Weekly/Localisation/Spanish.lngc     - not updated since 1.4
http://musicbee.niblseed.com/Weekly/Localisation/Svenska.lngc   - final
Traditional Chinese - not updated since 1.3
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update - no change from last week):
Last Edit: September 19, 2012, 06:40:38 PM by Steven
http://www.mediafire.com/?3isi4ap72qkvhh4
backup:
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4648.zip
this is the second release canidate for version 2.0 and contains a number of bug fixes since the last update
http://www.mediafire.com/?hx7ced1per7pbp0
localisation
Last Edit: October 06, 2012, 09:05:24 AM by Steven
http://www.mediafire.com/?h60gy3af099vj97
backup:
http://musicbee.niblseed.com/Weekly/MusicBee_2_0_4663.zip
the final release canidate for version 2.0 and contains a number of bug fixes since the last update, including ASIO playback speed on some devices, skipping tracks in a particular circumstance, and last.fm artist pictures not being retrieved
update for the internal browser (equivalent to firefox 16.1)
http://www.mediafire.com/?4p1ne8l0kw53f0w
localisation
Last Edit: October 13, 2012, 09:05:55 AM by Steven
links above have been updated as there was an introduced bug when playing single image files with embeded or external cuesheets
Last Edit: October 10, 2012, 09:29:17 PM by Steven
