Author Topic: Dark Skin - "Calabaza Nocturna"  (Read 12050 times)
pab_men
"Calabaza Nocturna"
Hi, I made this skin, "Calabaza Nocturna"  (maybe, some parts need to be polished  )
More shots:
- http://dl.dropbox.com/u/4423757/pab_men/musicbee/Untitled-1.jpg
- http://dl.dropbox.com/u/4423757/pab_men/musicbee/Untitled-2.jpg
- http://dl.dropbox.com/u/4423757/pab_men/musicbee/Untitled-3.jpg
- http://dl.dropbox.com/u/4423757/pab_men/musicbee/Untitled-4.png (new)
- http://dl.dropbox.com/u/4423757/pab_men/musicbee/Untitled-5.png (new)
Hope you like it!
Tested on Musicbee v1.3.4334, v1.4.4418,  v2.0.4432
Downloads:
> http://www.mediafire.com/?644i4kykqib7v
Update 29-feb-12
- New elements skinned (combobox, buttons, sliders, scrollbars).
- Compact/Mini player skinned/colored.
- Contrast issue solved (thanks VX).
Last Edit: February 29, 2012, 06:25:18 PM by pab_men
Analien
Hey! Very nice skin indeed! I especially like the framing lines. Good job!
I really like the name of the skin too.
ma_t14
VX
Thank you very much for the skin. It's almost perfect for me.
However, I can see one minor issue, which could be improved. When a white text is displayed on the yellow background it seems it needs more contrast. Perhaps change white letters into light brown ones for better readability.
I'd include it in MusicBee 1.4 final installer as it looks very professional.
Last Edit: February 29, 2012, 09:52:41 AM by VX
pab_men
@Analien:  Thank you  :)
@ma_t14:  8)
@beeing good: :D
 :o thx.
ma_t14
Thank you for the improvements. No matter how much I try can't find a fault to this skin. The only thing that I think would look better if changed are the buttons on the right of the seekbar (last.fm, equalizer etc)
I like how the playback buttons are round, maybe make the rest of the buttons round as well or "roundish" to follow the same trend. Or make them so that they stick together and look like one button (with rounded edges)... Hm...
It's up to you though, just a suggestion  :)
Cheeba
Thank you for this skin, I love it:)
Just one thing I need from this skin, Larger browse back & browse forward buttons as im using a 27inch multi touch monitor
Is there anyway to do this?
