Author Topic: Some suggestions for Fullscreen mode  (Read 9834 times)
7327203
- Fullscreen mode without menu bar. When I lock up MusicBee and someone else I don't know comes around, they tend to poke around and then cause some weird exceptions that I can't ever make. With no menu bar they will have less things to mess up (while I use a super-simplified panel setup), and unlocking can be made to use hotkey only so I won't worry about people trying all the passwords they can think of.
- Fullscreen mode with retractable player module. Just like in Firefox (and other internet browsers too I believe), pressing F11 gives you fullscreen with the controls, and then after seconds the controls collapse into the edge of screen. This can be useful when I want to maximize the area given to the library and/or playlists for visibility, like on a low-resolution large screen.
- Fullscreen mode without actually locking the entire computer. Sometimes I wish to just max out the area for information but still can ALT-TAB to other programs. This is also a bit like fullscreen in browsers where the entire screen is dedicated to what I'm looking at, and I won't have to go all the way back through the menus (or hotkeys) to get back to normal mode to check an IM message for instance.
- The above suggestions, at best should come at a tick-able choice like now :)
Keep up the good work MusicBee team!
Alexis
+1 for full screen mode, for when one has visualizer up.
I would like to just see the artist pictures or whatever is on the visualizer when I just have the music player going and sitting back.  No windows taskbar or player menu.
Moving the mouse  would bring up a menu to escape fullscreen mode or whatever may be deemed necessary... or maybe just hitting esc.
Greb
You can use the new screensaver plugin for that...
Alexis
I have noticed the implementation of the screensavers and been really curious, but I have not used screensavers in years.  I like the work you guys have done.  maybe I will give them a try, but still think I would like the option above, especially  to see the artists photos etc.  Maybe I will change my mind if I try the screensaver.
Update:
I tried the screensaver and it is really very cool but one would still like the option to just have fullscreen mode that one can actually interact with.
Last Edit: March 11, 2012, 06:28:46 AM by BeeFanatic
Greb
Update:
Some screensavers need to press specifically ESC to exit, so you can use the mouse or any other key to interact. You could propose it (I would create a new thread for it)  ;)
just regarding screen savers, in the longer term i anticipate that when they are docked inside musicbee or when displayed on multi-monitor computers where it is configured to allow other screens to be active that they will have interactivity eg. click the progress bar. The way i see it, the screen savers would be a way for users to create their own customised look.
I guess at that point calling them screen savers is not really a good name, and in fact even now i am not really happy with that name as i think it leads people to the wrong asssumption of what they are.
So any suggestions welcome!
you can already full screen a visualiser using Alt Enter
Alexis
Thx...I didn't realize that
i thought alt-enter was a pretty standard key for that, but seems F11 is for some people, so perhaps i will add a hotkey command
