From the Beta thread:
- new: <first(<field>)> function in a naming template - returns the first value from a multi-value field eg. if you have multiple artists for a file <first(<artist>)> will return the first one
I think I could use functions for up to 6, but I'd settle for 4, if you could do it. Still looking for a workaround to the line display issue in the Now Playing panel if multiple-field tags are set to display all values. Thanks.
