Author Topic: Dark Skin modification  (Read 13009 times)
richardap1
I have made this using the Dark skin as a basis and adding some purple. It is almost finished and if anyone wants it I'll add a link soon.
beeing good
Looks really nice. How do you get the buttons on the bar next to the search?
richardap1
You can add them from the hotkey page in preference
richardap1
beeing good
Wow, I didn't realise you could do that. Thanks!
beeing good
Looks really good. Thanks for your work on this.
dgbx
The buttons on the bar next to search are now reached by Edit/Preferences/Layout.  Then in the "main panel" section, use the "Edit" button next to "command buttons:".
Cheers!
