Author Topic: beeTunes Skin  (Read 149488 times)
Creaulx
  • Steadfastly Analogue
That did the trick - looks fab now!!!
charnode
+1 for making people believe I use iTunes while there is the nifty musicbee working under the hood.
Greb
A small bug, man. Check the color of the missing tracks. The alternative ones are not lowlighted, but keep the same color as normal.
cartman005
Greb, I'm not sure what you mean. Can you clarify?
vpsaxman
FWIW, if you want to further skin some elements, here's a great resource: http://blog.app-juice.com/?p=213
Greb
When some tracks are missing, they appear as lowlighted in MB.
But:
In your skin they appear alternatively normal and lowlighted. Both of them should be lowlighted (grey text).
Wolo
I don't think i will use it but i just want to say you've done an awesome work cartman005, bravo!
cartman005
Thank you everyone. I will try updating it further this coming week.
l.dc
I realised with this skin how moving the 'now playing controls' to the top instead of default bottom works wonders on MBee's looks!!!
Thank you :D
cartman005
I have made a few minor changes to the skin. Greb, I was unable to address the issue that you brought up yet. I haven't found any example of a skin without that issue.
Also, the skin needs a name. Since I can't call it "iTunes" and iBee is already taken, I was thinking something like Senuti (iTunes backwards)? It might be stupid lol, but if anyone has any suggestions, let me know.
Last Edit: December 27, 2011, 06:44:06 AM by cartman005
beeTunes?
also i will look at the colouring issue later in the week
Maleko12
beeTunes sounds cool with me. Besides, Senuti has already been taken I'm afraid  :-\
cartman005
ma_t14
Crap. Haha ok, beeTunes it is.
You forgot to update the filename  ::)
I found a bug, the text of the now playing track seems to go outside of the boundaries:
cartman005
I fixed the track info issue.
Last Edit: December 28, 2011, 01:42:30 PM by cartman005
