Author Topic: beeTunes Skin  (Read 150695 times)
adderall
hey could someone help me with making this look like the original picture? i specifically want the drop-down album display with the tracks showing. thanks 8)
http://i.imgur.com/aXJu97O.jpg
cartman005
Click the button to the left of the search box and select Album and Tracks.
wavebave
cartman005
Are you referring to the tabs bar? You can turn that off by going to Edit > Preferences > Layout (1). Under main panel, set the tabs bar option to Do Not Display and you won't see that.
wavebave
oh thanks didnt know you could scroll down lol
btw why do some of the buttons look like this? http://puu.sh/bwVC1.png (only half of it is showing)
cartman005
I'm not sure. Do you have your screen DPI set really high? I might have to see the entire window.
cartman005
Everything in that screenshot definitely looks enlarged from the regular size but I tried increasing my DPI and I can't get it to happen. Does it happen regardless of your window size? Any other skins doing this?
the released v2.4 version handles high DPI scaling better than older versions
Ansem
i really like your skin! but you will ever release a dark theme?
vpsaxman
iTunes 12 is around the corner and it looks great! It would fit perfectly with Windows 8. Just saying...  ;)
Check it out: http://9to5mac.com/2014/07/21/screenshots-of-redesigned-itunes-12-for-os-x-yosemite-gallery/
cartman005
Yes, a version for iTunes 12 will probably be my next project. A black one would be nice but it will require me to pretty much start from scratch so I can't promise that I will get around to it.
vpsaxman
Nice to hear! iTunes 12 looks great IMO. A dark version would be really awesome, but it sounds like a lot of work as you said. Keep up the good work!
Ansem
thanks a lot for all your work :D even if you'll never do the black version your work is still great :D
Chaython
I hope you started working on a Itunes 12 version. Itunes 12 has been available for a couple of weeks on Windows and a year on Mac. http://support.apple.com/kb/DL1615
The latest MusicBee patches.
