Author Topic: "Charcoal" a Unibody Theme  (Read 14849 times)
dannyboiii
This is my new theme! Woot, I'm pretty sure it's a lot better than that other test theme I made as well :) All of the main interface is done, so it definitely feels great while you're doing anything in the main window, but--as a reminder--this is kinda like a beta. I've yet to skin the miniplayer or preferences dialogue. Big thanks to  Blinghound, as I based this theme on his iBee Dark Theme, and there are still many parts of that which are in use.
Screenshot with Borders   http://i26.photobucket.com/albums/c105/DKandel/Untitled-1-1.jpg
Main Screen  http://i26.photobucket.com/albums/c105/DKandel/screen-3.jpg
Artist Information  http://i26.photobucket.com/albums/c105/DKandel/charcoal3.jpg
XML Link: http://www.mediafire.com/?yogt341zda9lus6
IMPORTANT.
In order for this theme to be viewed correctly, you must:
        1. Make sure the player controls are moved to the top.
        2. Make sure "View < Skins < Skin Window Borders" is checked.
VX
Looks quite good, but the main bar menu entries (File, Edit, View....) are invisible unless hovered over.
richardap1
Actually i think i might like the hidden Menus. I'll try it out for a while. Nice work
i was tossing up whether to have the menu auto-hide when the player is docked to the top because of the visual clutter it creates in that layout but in the end i thought it didnt look to bad.
I'll look to implement it for the next update as i dont think its a good idea to have the menu permanently invisible because it will inevitably lead to people raising bug reports
dannyboiii
Yeah, the  menu being invisible unless hovered over was an intentional choice. I've always been an avid advocate for the death of all menubars. I could see how people would be hassled by this, but really, I've mostly created this skin to suit my own personal aesthetic preferences.
I like the auto-hide idea you  have stephen, I think it would really make the whole interface look a lot nicer, and would definitely give musicbee another advantage to other music players like songbird or itunes.
ma_t14
Couldn't agree more with this statement  :)
i've added a setting in the skin file
  <element id="AutoHideMenu">true</element>
when set and the player is docked at the top, the main menu will auto-hide
beeing good
Thanks for this Steven, this is fantastic!
