Author Topic: Additional Tagging & Reporting Tools  (Read 929626 times)
WimYogya
@boroda74
Since I use the new release of both MB and ASR the ASR performance is sooooo muuuuuuch sloooooower....
Often it takes 4 seconds per track update, so 50 tracks take more than 3 minutes.
Do others have this experience too?
Or should I change any setting?
WimYogya
retired Dutchman (1944) in Yogyakarta, Indonesia
WimYogya
@boroda74
Would you please consider to add 2 more presets:
1. Remove # characters from the beginning/end of field x
2. Add text xxxxxxxxxx to the beginning/end of field y, separated by z
Thanks!
WimYogya
i think this is because plugin now updates ui every 5 sec. instead of just at the end of operation. i dont want to change this behavior.
WimYogya
[/quote]
[/quote]
I am not sure if I understand the change. Why not change back if it slows down so much? Update of 1000 tracks = 4000 seconds = more than 1 hour...
WimYogya
@boroda74
In the most recent ASR version some bug might have entered. Please check.
In the preset Add up to 2 leading zeros in track numbers I tried to change (example)
1 2 3 4 5 6 7 8 9 10 11 12 13 14
The result shown in the preview is correct (only added an extra zero from 1-9)
But the final result included:
010 011 012 013 014
In earlier versions this was not the case, I used the preset 100's of times.
Please inform when an update is available. Thanks.
cant confirm this. try to reimport all presets.
New plugin version  released:
  • Some bugfixes
  • New ASR presets
http://www.mediafire.com/download/a1rub2vt7btow9w/mb_TagTools_2015-03-09.zip
redwing, an issue with file timestamp is still unresolved, but i'm going to take a look at this.
Thanks for the update!
- Copy/paste selected tags commands are now working great with lyrics & artwork fields. I'm going to update the guide about this feature.
- "Extract featuring artists from title..." preset is working fine, but what I meant by "(Guest) Artist" was that it could copy to either Guest Artist or Artist tag. Can you add one more preset that copies to Artist tag? A note to other users: this preset works fine for a single featuring artist as well, and if a track has more than two featuring artists, use the same "custom text 2"( a comma or &) between them in title field before running this preset to the track.
- As you said, mp3 replaygain preset issue remains unresolved.
- Now included presets are almost 90. How about adding a search box to the dialog so that people could easily locate presets they are looking for?
its done
http://www.mediafire.com/download/7wq4fff8bkc0riv/mb_TagTools_2015-03-10.zip
still to do
nirolf
@boroda74
I'm having a problem with auto-rating. After I change some presets (see screenshot) it works OK (though the ratings don't change, only Custom9), but after I restart MB I get this error:
MusicBee v2.4.5404.16303 (Win6.1), 19 Mar 2015 17:34:
   at MusicBeePlugin.AutoRatePlugin.InitializeComponent()
   at MusicBeePlugin.AutoRatePlugin..ctor(Plugin tagToolsPluginParam)
   at MusicBeePlugin.Plugin.autoRateEventHandler(Object sender, EventArgs e)
   at #=q9DbaPkf98Bwnsb8WzYcjp0RNJK2ABsR7K3qLJHpRAZU=.#=qZZJUsWw6tR8pvhvDIsy$2g==(ApplicationCommand #=q4OrOPUtIo9ZMXVwHmwTogw==, Object #=qKixOGksuZIqNarZ4TufoBw==)
Could you please have a look?
plugin cant create auto-rate class. looks like your .net is corrupted. try reinstall .net
nirolf
I have reintalled the framework and even tried on another computer, still the same. It seems to trigger when I check "Auto calculate thresholds on startup".
MusicBee v2.4.5404.16303 (Win6.1), 21 Mar 2015 13:28:
   at #=qkqD_24K_jqNNsY4ytXfL8gdU4AeJG50yEcwQQ82gVnW0tjNMKqAPXQTcHSTEGGUx.#=q_BllApB1jquyAgblsRWAGQ==(Object #=qHIgSGJS$_ycrUlpxd6kRrg==, EventArgs #=qdjAGRgNuykZe8nBxToZIxg==)
Working good! But it doesn't allow to resize the window.
