Author Topic: Additional Tagging & Reporting Tools  (Read 935753 times)
Pingaware
Sorry boroda, got what I assume is the same report again -
MusicBee v2.4.5330.22939 (Win6.1), 6 Aug 2014 11:47:
System.Runtime.InteropServices.ExternalException (0x80004005): A generic error occurred in GDI+.
   at System.Drawing.Image.Save(Stream stream, ImageCodecInfo encoder, EncoderParameters encoderParams)
   at System.Drawing.Image.Save(MemoryStream stream)
   at System.Drawing.ImageConverter.ConvertTo(ITypeDescriptorContext context, CultureInfo culture, Object value, Type destinationType)
   at System.ComponentModel.TypeConverter.ConvertTo(Object value, Type destinationType)
   at MusicBeePlugin.LibraryReportsPlugin.previewTrackList()
   at MusicBeePlugin.PluginWindowTemplate.serializedOperation()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Threading.ThreadHelper.ThreadStart()
Pingaware
Sorry boroda! This is the error report from the one without artwork resizing:
MusicBee v2.4.5331.30657 (Win6.1), 7 Aug 2014 13:57:
and with the artwork being resized:
MusicBee v2.4.5331.30657 (Win6.1), 7 Aug 2014 14:08:
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
   at System.Threading.ThreadHelper.ThreadStart().
If it's any help, the reports are crashing slightly earlier now - 37% for the no resize and 94% for the one with resizing.
Pingaware
Failure's changed place - it now occurs at 83% without resizing with this error:
MusicBee v2.4.5332.32253 (Win6.1), 9 Aug 2014 15:58:
System.OutOfMemoryException: Out of memory.
   at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
   at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height)
   at System.Drawing.Bitmap..ctor(Image original, Int32 width, Int32 height)
   at System.Drawing.Bitmap..ctor(Image original)
and 95% with resizing producing this error:
MusicBee v2.4.5332.32253 (Win6.1), 9 Aug 2014 16:05:
Thanks for the effort you're putting into this boroda!
Last Edit: August 09, 2014, 04:11:57 PM by Pingaware
Pingaware
Same again by the looks of it. Without resizing:
MusicBee v2.4.5332.32253 (Win6.1), 9 Aug 2014 22:15:
and with resizing:
MusicBee v2.4.5332.32253 (Win6.1), 9 Aug 2014 22:21:
Pingaware
Pingaware, sorry for delay, I was very busy at my work.
Oh don't ever worry about apologising for taking a while to post! I'm grateful enough as it is that you keep spending all this time trying to (and succeeding in) solving all the bugs I keep digging up for you. Thanks for the effort you always put in - I don't mind about a little wait.
Unfortunately still crashing - 82% without artwork resizing
MusicBee v2.4.5339.22204 (Win6.1), 14 Aug 2014 22:02:
and 95% with resizing:
MusicBee v2.4.5339.22204 (Win6.1), 14 Aug 2014 22:08:
Hmm. Seems to be the same error. I should prepare a debug version.
@Pingaware
Create folder C:\Temp, install debug version:
http://www.mediafire.com/download/99qpe0ij991lkds/mb_TagTools.dll
, run LibraryReports and send me Log.txt from C:\Temp.
making report will be slower than usual. Its normal.
Hey boroda74, you look busy lately. When you have time, would you have a look at this request?
With the current functionality, it's possible to copy & paste a single tag between multiple files (http://getmusicbee.com/forum/index.php?topic=13643.msg82206#msg82206). But no way for multiple tags.
So it would be great if the plugin could read and split clipboard data with a user-defined delimiter and then write each of them into multiple fields. For instance, the user enters "<Title>*<Artist>*<Album>" in the 'send to clipboard settings' box. Then runs copy tag command, and selects something like "<Clipboard-multiple>" for the source , "<Multiple>" for the target, and "*" for custom text. Then the plugin splits the data and writes each value in the corresponding field. What do you think?
... What do you think?
It would be very complicated for copy tag command, but probably I could do this for ASR. I'll look at this later.
Then would it be possible to select multiple tags from the preset instead of entering into the clipboard setting box?
