Author Topic: Additional Tagging & Reporting Tools  (Read 935603 times)
As I said only mp3 & m4a track gain to soundcheck conversion presets matter. You should be able to reproduce it with those two.
Hmm, and SoundCheck custom tag is stored in database only? Or is mapped to 'COMM/iTunNORM'?
Of course it's mapped to COMM/iTunNORM field through an auto-playlist. Basically they are configured the same as the guide I wrote: http://getmusicbee.com/forum/index.php?topic=9600.0
I really wish you could fix this bug before Steven updates Track Previewer plugin. As you may remember, this is an old issue that made me stop using your iPod & iPhone plugin.
@redwing
I can't reproduce the issue. Please run debug version of plugin:
http://www.mediafire.com/download/1sw49c31rd26yws/mb_TagTools.dll
Post a links to files AppData\TtErrorLog1.txt and AppData\TtErrorLog2.txt
The new presets write SoundCheck values like "\@rg2sc4mp3(-7.2 dB)". Is this correct?
The new presets still update file modification date responding to skip count changes.
This?
http://www.mediafire.com/download/c6fq3vtwf8j1cqb/mb_TagTools_2014-06-21.zip
Notice that both plugin dll AND asr presets are modified. Also combined track/album presets will modify files anyway (unfortunately).
No differences. And I only use track gain conversion presets.
One thing I noticed is that they don't update tracks played at least once with these new presets. So do I need to rewrite SoundCheck values for all my tracks?
Again they write SoundCheck values like "\@rg2sc4mp3(-7.2 dB)".
Yes. But subsequent applying of preset shouldn't modify files.
