Hi Boroda, long(ish) time, no bug report from me.
When the plugin is activated in MB, and a second monitor is connected (or disconnected) from the computer while MB is open, MB freezes and has to be manually closed by killing the process in Task Manager. This doesn't happen when the plugin is disabled. Haven't been able to test whether it happens if there isn't an auto-report enabled (my auto-report is always enabled and I don't have much time for bug-tracing currently).
Also, a minor one. If an auto-report is cancelled using the cross which appears in the status bar, you can't then access the auto-report menu as the message "Background auto-report is still running!" pops up.
