Perhaps i'm doing something wrong but i have the same result.
This is what i did:
I have made a copy of the original preset in order to modify it, opened with "Rename/Edit", erased the old regex in the "search for" field and copypasted the new one from your post.
The result was the same, i think the regex you posted is the same as in the original preset.
Does this make sense?
Thanks
