Author Topic: Additional Tagging & Reporting Tools  (Read 934450 times)
@phred, its because you've downloaded 02-09-2 plugin version instead of 02-09. to use 02-09-2 version (the only difference between these 2 versions is that 02-09-2 supports for new tags, recently added to mb by Steven) you need mb 3.1 latest patch:
Yes, my bad. I thought I was using the latest patch, but apparently not. Thanks boroda74.
Also, I like the new confirmation on auto-applying presets! I have found one thing that doesn't work as I believe it should. I'm using it on the preset 'remove leading zeros in '<Tag 1>' -2. It works as expected when I edit a track number that is 01. But when I remove the track number completely, the confirmation window also pops up. I don't think it should be asking for confirmation in a case like this.
But thanks for adding that feature.
@phred
http://www.mediafire.com/file/bzdr7aqxya3bvok/mb_TagTools_2017-02-10.zip
it seems that there are some bugs with confirmation checkbox on manual applying presets, but now is deep night, i'm sleepy and edit: cant reproduce these bags.
Last Edit: February 10, 2017, 07:03:50 AM by boroda74
There's still an issue ... I deleted a track number and did not get the confirmation, which is good.
But when I added track number 013 and clicked 'save' I got this
After clicking 'ok' the expected confirmation popped up. And now, if I manually edit a track number to 013, there's no confirmation nor does the leading '0' get removed.
@phred
i've forgotten to remove debugging popup window, but i'm sure there is still some real bug. here is plugin with debugging widow removed:
http://www.mediafire.com/file/xcarqxt9pw69xjd/mb_TagTools_2017-02-10-2.zip
frankcreed
redwing, please test new asr preset 'replace unicode punctuation marks...'
phred, psychoadept, please test new option 'ask confirmation before auto-applying this preset' in main asr window.
frankcreed, i've received Stevens comments on new tags, but its not implemented yet.
http://www.mediafire.com/file/9i97ha7peugjsrx/mb_TagTools_2017-02-09.zip
Hi Boroda,
Thanks for implementing the changes!
Sorry, I've been behind!  I just tested out the new confirmation setting.  I'm not sure how it's supposed to work.  When a setting is ticked for auto-apply, you have to also tick the confirmation setting?  Otherwise it behaves as before, and goes straight to auto-apply?
Pingaware
Been a hell of a long time since I've been on the board, so of course I return with a bug report.
14/01/2017 16:52:59 - 10.0.14393.0 - 3.0.6190.36802 - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentNullException: Value cannot be null.
Parameter name: String
   at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
   at MusicBeePlugin.Plugin.ReceiveNotification(String sourceFileUrl, NotificationType type)
   at MusicBee.Plugin.#=qGVXp5ZoITKKwGWjTtr1As43kOnRgnp$zA2OSSytwaBE=()
I think this has been happening since sometime after the 05/02 (that's the last time my auto-report seems to have run) - I only noticed that the plugin was disabled when I couldn't access the S&R screen yesterday. I'm on the latest MB patch and the latest version of the plugin (from 10/02). Now every time I try to enable the plugin from within the preferences screen, I just get the message: Unable to initialise this plugin. Exception has been thrown by the target of an invocation.
Any ideas?
EDIT: Just had a look through my recycle bin. Based on the versions of MB I've recently downloaded, I'd say it's probably some sort of conflict that's occurred due to a change between the MB version on 04/02 and the current version.
Last Edit: February 19, 2017, 03:04:02 PM by Pingaware
Try patching to 3.1
Pingaware
Just checked - I'm on 3.1.6256
The plugin is working for me, but I'm getting the same error message as above, about 2500 times just in the last day.
@all
can't reproduce this bug.
try this plugin version:
http://www.mediafire.com/file/333ora4bh7s1p2m/mb_TagTools.dll
i need to know if error window (not confirmation dialog) with text "null!" will pop up for you.
Last Edit: February 21, 2017, 07:45:06 AM by boroda74
if preset is not ticked for auto-applying then it it doesn't matter if confirmation option is ticked or not. also confirmation option does nothing when you manually apply preset.
That's all fine, but I don't think it has solved the problem. The change needed is the ability to make a preset NOT automatically applied with one click.  It still only takes one click to mark the box next to a preset.  There needs to be an opt OUT for confirmation of applying a preset, not an opt IN.  Ideally this would be a global setting, maybe in the configuration panel.  Something to the effect of "Do not require confirmation when applying tag changes automatically"  (my preference would be to receive a confirmation when you tick the box fur the preset, but receiving it when tag changes are triggered could work, too.)
Last Edit: February 21, 2017, 05:21:39 PM by psychoadept
Piwilelapin
Hi !
Since I've used the TOY change case command with advanced tagging tool, the numbers in my titles appear this way: "Ii, Iii, Iv, V, Vi"
The exceptions is about putting words in lowercase, so I'm not sure what to use.
Does anyone of you know ? :)
