It works with a simple html and text file, but if I export it as an html document, I get this error (sorry, it's dutch):
''MusicBee v3.0.5995.40050 (Win6.1), 10 jul 2016 17:02:
System.IO.DirectoryNotFoundException: Kan een gedeelte van het pad F:\Program Files (x86)\MusicBee\Plugins\Artists.files\t.files\stylesheet.css niet vinden.
bij System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bij System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
bij System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
bij System.IO.FileStream..ctor(String path, FileMode mode)
bij MusicBeePlugin.HtmlDocument.writeHeader()
bij MusicBeePlugin.LibraryReportsPlugin.exportTrackList()
bij MusicBeePlugin.LibraryReportsPlugin.buttonOK_Click(Object sender, EventArgs e)
bij System.Windows.Forms.Control.OnClick(EventArgs e)
bij System.Windows.Forms.Button.OnClick(EventArgs e)
bij System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
bij System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bij System.Windows.Forms.Control.WndProc(Message& m)
bij System.Windows.Forms.ButtonBase.WndProc(Message& m)
bij System.Windows.Forms.Button.WndProc(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)''
The main error means ''Can't find part of path'', and then it can't find stylesheet.css.
