@boroda
Did what you suggested, even more: downloaded the newest plugin version > closed MB > deleted the old plugin parts in my MB folder > extracted the newest version there > restarted MB > activated ASR > imported all presets > did a new test > same result.
As the attached .jpg shows: the ASR screen PROMISES to leave 10, 11, 12, 13 unchanged, but as the results show it DOES CHANGE them into 010, 011, 012, 013.
(And if you repeat the same test the result is even stranger: 07, 08, 09, 010, 011, 012 change into 007, 008, 009, 10, 11, 12).
http://imgur.com/YrhG5IOLong time ago I personalized a number of the default presets and put them on the top of my ASR-screen, but for this test I used 'your' unchanged default preset that promises to add zeros.
What is wrong?
