Ok, I'm using Subsonic server version 6.0 and plug-in version 2.9 (beta). For some reason, I can't get any music to show up in my MusicBee library. I'm using the same address and credentials that I use successfully with the Subsonic web UI, SubAir, and DSub on Android. I don't get any errors when I configure the MusicBee plug-in, and Subsonic shows up as a "drive" when I create a new library. However, after I have everything set up, no music appears in the MusicBee UI. If I use the re-scan library option in MusicBee, it immediately says that the re-scan is complete and no new music was found.
Any ideas? Thanks!
