Author Topic: BEER skin  (Read 21758 times)
Sarge
I took the color elements of a ice cold beer, along with the colors from a Budwieser Label and made this skin.
BEER BEE
***Fixed a highlight issue on the menu Drop Down  5-25-2011 ***
SKIN FILE:
http://www.mediafire.com/?a4a9u6v586d7e5u
above screenshot using the font Segoe UI  10 pt Bold
My next upcoming skin is , Pepperoni and Cheese Pizza w/ Mushrooms Bee
Last Edit: May 25, 2011, 05:20:46 PM by Sarge
Elfarrat
damn.. i'm getting thirsty... nice one  ;D
Sarge
When you said Nice one.....did you mean  the Skin.....the Beer......or the picture of P!nk   ;D
j/k have a great day and thanks for comment.
Guegs
Oh man this is amazing! Thanks!
Sarge
thank you for the comment and feedback, nice to hear you like it
Sarge...
I used this skin three times and then switched to WTF.  Now I'm getting dizzy.
Can't wait for the pizza.  Between the beer and the pizza I'll probably gain ten pounds just listening to music.
Nice job.  I raise a pint in your honor.
yes nice job sarge - i know from my own experience doing a couple of skins how much effort and skill is involved with getting it right.
Sarge
Sarge...
If you are afraid of gaining weight just use the Watermelon skin.....It's non-fattening.
thanks for the comments and the laffs.
thanks also Steven for the comment
jackuars
I just don't know how to express that how wonderful this skin is. But there is something that i don't like or personally speaking what i would change if i was the creator. The lyrics and details tab on the right that can be switched, you've coloured yellow for the highlighted one, but i guess the grey would be better for the one thats highlighted because when you have the 'details' highlighted it gives a sense that the chosen tab is 'lyrics' because it blends perfectly to the colour just below. Anyways, nice job and should be my default skin for weeks..:)
Last Edit: May 09, 2011, 10:21:53 AM by jackuars
Sarge
thanks for the comments,  and I don't disagree with you on the Tabs, and I tried to change them as you suggest. I'm having a hard time doing so, and it should be easy (but it ain't  :)  ) and when I get it done I will let you know.
thanks again
jackuars
plesase do check the icons on the right. The toggling of shuffle icon to on and off needs to be worked upon as the user cannot distinguish between both
Adson
very nice skin  :)
You should add a kind of bell button to order the next beer. Maybe it works and someone brings one ;-)
Of course only a non-alcoholic one because of the younger users ;-)
Definitely very good work, well done!
Thanks for the beer.
A.
Sarge
very nice skin  :)
A.
hey Adson, thanks for the feedback and the comments.
I certainly don't advocate under-age drinking, but if you are of age you should consume as much as possible.  ;D
**Please note i was only joking, you should never drink and operate MusicBee at the same time  !
Sarge
I made a update to the skin..thanks for bringing to my attention
I also fixed that same issue on the Chocolate Skin and I will check the others soon and fix if necessary
Last Edit: May 11, 2011, 08:43:51 PM by Sarge
beistrich
@Sarge
How did you change the color of the volume slider?
I'm still working on my metro-style skin. But i can't change the volume slider color.
