MB is a really nice music player. But (for now) it has a little problem: layout is really hard to configure. Probably that'll be solved in the future.
Until that moment, I think it would be a good idea to upload screenshots and instructions to set up MB that way. I'll be posting some ones when I want to make a break but, of course, everybody is invited to do so.
This is a really nice layout I love:
To get it:
- Preferences > Layout > Now Playing panel > Right sidebar option checked
- Preferences > Layout > Now Playing panel / Configure panel > Show now playing list unchecked
- Preferences > Layout > Now Playing panel / Configure panel > Show Artwork unchecked
- Preferences > Layout > Now Playing panel / Configure panel > Show Lyrics panel checked, below Track details
- Preferences > Layout > Now Playing panel / Configure panel > Show track details checked, artwork above fields (size 300 px)
- Preferences > Now Playing > Now playing information > Show information for the playing artist in the bottom panel
(that way you have one arrow in the center panel, at the bottom right corner, if you press it the artist information is showed)
If the now playing list is at the right and you don't want to have it there, go to the contextual menu in 'Track information'>Configure Layout>Now playing list>Hide playing list.
To show the 'now playing list' in the center panel the easiest way is:
1. Open a new tab with the icon (a folder with a '+' sign)
2. In the left panel go to 'Playlists' and select 'Now playing'
In case you want to use the Library Explorer to browse your collection, that way:
1. Go to the left panel. Then look at the right bottom corner. There is a arrow there.
2. Press the arrow and the Library Explore will open.
