Author Topic: 'Honeycomb' Skin  (Read 41257 times)
Blinghound
Update
@Steven
I've elongated the track detail bar in order to remove some of the space on the right. Do you prefer this? Or does it look better centered?
@beeing good
I've taken off 18 pixels from the bottom bar in both versions. I do agree, it did take up too much room. What do you think?
beeing good
That's definitely an improvement, good work!
Thanks again  :)
Blinghound
Cheers everyone for the comments. Again, this was only a starter bitmap skin, and I plan on improving it more.
fredphoesh
Hi there Blinghound,
I am using and enjoying your skin, thanks...
I was trying to add a folder to the library and could not with success, because apparently there is a little box which has to be ticked before you say OK to add a folder to the library... well that little box is invisible using Honeycomb.
I am now adding a huge folder to my library, so when it is done I will do a screen grab for you, but it is definitely not visible (certainly to me, on my computer ;)
Thanks,
Mark.
Blinghound
Hey Mark, I had a look for you - are you refering to this square?
Cheers for your help
fredphoesh
hi there,
Yes thats the one... I couldnt see it was there!
tx
Mark.
LucTemetNosce
Hi! This seems like a lovely skin, but apparently the mediafire links are down. Is there any chance any of you can upload it to Drive, Dropbox or somewhere else?
