Author Topic: 'Honeycomb' Skin  (Read 41169 times)
Blinghound
Honeycomb
Light Player                         Dark Player
Light Player Version: http://www.mediafire.com/?kwz2wjieipbgg1p
Dark Player Version: http://www.mediafire.com/?ivxuvxkj3g2u448
Non-Bitmap Version (Original): http://www.mediafire.com/?gej8142jbcpvp46
Version 1.3.4221 required: http://www.mediafire.com/?24ujygzcmgil42l
This is a very early attempt at creating a bitmap skin using the original Honeycomb as a base, and I will inevitably make improvements as and when I have the time.
Any ideas/criticisms are welcome. Hope you all enjoy it.
To use, simply place the .xmlc files into the [location of installation]\MusicBee\Skins\Dark\ folder, then select the skin of your choosing within the View|Skins menu in MusicBee.
Note: The MusicBee version required for these skins to work has not been officially released, so use the non-bitmap version if you are unwilling to use the latest beta.
A special thanks to Rotem K. and Steven for their patience.
edit: changed MusicBee link
Last Edit: July 29, 2011, 03:45:49 PM by Blinghound
greenday1987
  • Long live OiNK!
Epic, thanks :)
RIP OiNK
Blinghound
Update
I have updated the links to include:
- New 'delete' icon (in status bar)
- Changed colour of the lines under the artist names in 'Album and tracks' view
- Changed colour of text in the right sidebar header
Thanks to Steven for making the new elements to support these fixes :)
thebops
Blinghound
Update
The links have been updated to include:
-New minimise/maximise/close buttons with 'golden' highlight colours (available from version 1.2.4052 - available in Rotem K.'s 'Pop Pink' skin thread)
Again, a special thanks to Rotem K for allowing me to use his 'indented' style buttons, and to Steven for making highlighted buttons available
-New delete button
-Slightly altered splashscreen (transparent corners)
-Fixed the Mini player's nowplaying list icons
-A few other misc fixes
Feel free to leave comments about improvments and report any bugs!
Blinghound
Rotem K.
Blinghound
Update
I have updated the links to include fixes for a couple bugs that Steven and Rotem brought to my attention (thanks again)
- Disabled control buttons in the Mini Player have been corrected (the buttons were grey before)
- The Love icon in the Mini Player has been adjusted to be in line with the stars
- The default love icon in the main player has been adjusted to be the same colour as the stars
- In the edit menu is docked in the main panel, the highlighted tab colour has been altered - and consequently so has the 'playing track/selected track' bar in the right hand dock.
Blinghound
Update
-Fixed highlighted tabs in edit screen and right side bar
-Made file 100kb smaller
nishidake
This is my absolute favorite MB skin  ;D
Blinghound
Update
New bitmap versions available. Refer to the first post for instructions.
ma_t14
@Blinghound
The links provided are broken (they link to "http:///")
EDIT
Followed your instruction but cannot find the skins within musicbee
Last Edit: July 23, 2011, 09:28:35 PM by ma_t14
Blinghound
@ma-t14
Sorry about that, the links are fine now.
Which folder did you put them in? Did you download the latest MB version?
ma_t14
C:\Program Files\MusicBee\Skins\Dark
MusicBee 1.3.4221
