Author Topic: 'Midnight' Skin  (Read 35670 times)
VX
The Midnight skin is included in MB 1.2.4054 package .  Thank you both, OrB and Steven  :)
Steven, make sure you update the About MB Credits with the next release.
OrB
border fix in preferences
Thanks VX. Enjoy
VX
OrB, while skimming recent posts on the forum I noticed the suggestion to change the splash screen for Midnight Skin.
I had splash screens disabled in the preferences so I didn't know how it looks. After enabling the option I fully support the change suggestion. This naked guy at the splash screen doesn't really fit Your awesome skin.
OrB
new splashscreen
VX, i agree - thanks to indicate this point
i have spend no time in my splashscreens.
this new one is my first work with Incscape. What you think?
VX
The link was removed. I'll check it later.
UPDATE:
Great work, OrB ! The new splash screen is original and perfectly fits the Skin. Thank you :)
It seems a little smaller than other splash screens though. It's not a problem for me, but maybe others would prefer slightly bigger one ???
I hope Steven will include your superb skin in the next major update of MB and make sure to update the About/ Credits info.
Last Edit: February 18, 2011, 12:07:12 PM by VX
OrB
update to new skin elements - small changes
VX
Thank you very much for updating the skin. It's one of my favourites  :)
OrB
updated : missing elements for Radio Stations & small change to AutoDJ
WimYogya
Hello,
I am a long time user of the Midnight Blue skin. I love it.
There is, however, one annoying detail:
the command buttons in the top panel are hardly readable, because there is very little difference between the dark grey background and the black font color.
It cannot be adjusted - at least: I do not know how.
Can you please enhance the contrast (with white font?) or suggest any other solution?
Thanks,
Wim
WimYogya
retired Dutchman (1944) in Yogyakarta, Indonesia
