Author Topic: status bar info for scanning for files  (Read 7209 times)
kapblat
i'm installing MB again and i noticed that when its scanning for files there is no info about that - if its still scanning or its stopped, in the status bar :)
i consider that a bug if its not showing which file its scanning - i'll look into it. But did it show any of the files as it was scanning?
kapblat
i wasnt clear enough, sorry
it happened with a fresh install, then in the settings i added the folders, set to scan at startup,
closed MB started MB, and i didnt see it in the status bar
ok, the scanning on startup runs in the background after MB has initialised and displayed - i guess it could only show the new files its adding as a result of the scan otherwise it will be distracting if it showed all the files it scanned everytime it starts up.
Might I suggest something (perhaps) even simpler?  Pesonally I don't need to know -which- new files have been added/scanned.  But I'd like to know -when- scanning is taking place.  Maybe an indicator somewhere in the window that is green when scanning and red when not.  A box with the word 'scanning" which then changes color when it's active.  Something along those lines.
