Author Topic: Korean Translation  (Read 10190 times)
sheppaul
The translation is basically done using english base file + v3.1 in Progress, hiccup's reference for english file. Thank you.
After that, adjusted new entries and changed items using a new english base file (EnglishGenerated3_0.dat, 2017-06-19 16:56).
Translation for MusicBee v3.1
https://drive.google.com/open?id=0B3KXO1RI6zr3M25BTXdJLVBrYXc
Last Edit: June 24, 2017, 03:12:22 PM by sheppaul
sheppaul
sheppaul
The link is updated. It's for upcoming MusicBee v3.1.
sheppaul
The translation is updated in a same link for MusicBee v3.1.6385.
sheppaul
The translation is updated in a same link for MusicBee v3.1.6388.
sheppaul
The translation is updated in a same link for MusicBee v3.1.6422.
this is the binary version that will be included in the final release package:
http://musicbee.niblseed.com/Weekly/Localisation/Korean.lngc
sheppaul
Steven, please make sure the binary is from the latest translation of my work. I found some strings not translated in RC1 version.
The file size of the latest version is 220,012 bytes for Korean language.
ps. It seems you have already corrected in the binary file above. :)
Last Edit: August 13, 2017, 03:37:21 AM by sheppaul
That was an issue for all translations. Its fixed for the direct links and will be in the next RC version
