When you drag individual files, MB will use the order windows has chosen which means the first file will be the one highlighted when you start dragging (if you start dragging from the first file in the album then it should be in the order you want). If you drag the folder then MB applies filename sorting
Thank-You for the explanation, it worked Ok by dragging and dropping from first song of the album
into MB, Cheers for that.
Now as for FileName sorting, do you mean it is going to sort it in alphabetical order when I drag & drop the album
it self into MB ??, Also, are there any FileName sorting settings in MB ??
