Author Topic: Collapsable folders for playlists  (Read 1358 times)
sleepless
I know this has been mentioned before. When you have a large number of playlists (100+) it is aggravating to scroll through the whole list constantly. Please allow for playlist folders (in the playlist manager) to collapse so that these lists won't be so long.
Are you using v3.0 and the Playlists panel?
If so, update to v3.1
Otherwise if you want to stick with v3.0, then the playlists collapse when used from the left sidebar navigator
