Hi Steven
- The file with the issue:
https://drive.google.com/open?id=0B0qo0VmlMWr6R2ZvNmJVUjFsV0k- The sync renaming settings:
- As you can see, there is no rule to convert this file
- Here is the result of the sync I retried today:
As you can see, there are multiple errors, but only the first error is a real one... other files have no reason to produce an error (and when synced without the faulty first file in error, they do not generate any error)
Also, despite the errors, ALL files were transferred
- Here is the correponding log trace (for files in error):
- Once the previous sync was over, I retried a preview, with this strange result:
- And here is the result when trying to Sync. I did not go further, as the whole folder could have been deleted on the phone:
(by the way, note the small pb of localization with the English sentence in French mode... not sure I had reported that already)
- For what it is worth, here is the properties of the file in MB:
- And here are the properties on the phone:
Hope this is not TOO much info
Thanks for your help
Cheers
