Author Topic: Music Scheduler  (Read 32623 times)
Description
Plugin allows scheduling playback/start playback on MusicBee startup of multiple static or autoplaylists or Auto-DJ.
NOTE:
Plugin has options to prevent PC and monitor from sleeping if MusicBee is playing music. It doesn't matter if playback is started by plugin or manually. The only requirement for the options to take effect is that the plugin must be installed and enabled.
Screenshot
Download
Provide feedback on this topic.
Last Edit: August 26, 2023, 04:31:51 PM by boroda
theG
Going to test this. I needed exactly that last year for a few events and might need it eventually
Edit:
Using the last 3.1 patch update.
Created a task and when I pressed OK I got this:
MusicBee v3.1.6266.27069 (Win6.1), 26 févr. 2017 13:39:
System.ArgumentOutOfRangeException: L'index et la longueur doivent faire référence à un emplacement situé dans la chaîne.
Nom du paramètre : length
   à System.String.Substring(Int32 startIndex, Int32 length)
   à MusicBeePlugin.Plugin.DeleteTasksByPrefix(String taskNamePrefix)
   à MusicBeePlugin.TasksForm.buttonOK_Click(Object sender, EventArgs e)
   à System.Windows.Forms.Control.OnClick(EventArgs e)
   à System.Windows.Forms.Button.OnClick(EventArgs e)
   à System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   à System.Windows.Forms.Control.WndProc(Message& m)
   à System.Windows.Forms.ButtonBase.WndProc(Message& m)
   à System.Windows.Forms.Button.WndProc(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Last Edit: February 26, 2017, 06:42:01 PM by theG
theG
its fixed:
Yes, working now.
I'm testing it out and:
- If a song is playing and the scheduler task kicks in, I think it should wait for it to finish.
- Maybe the possibility to add days of the week in "Start date"?
- When the task kicks in, it loads the playlist but plaback is stopped.
many bugs are fixed. week days support is done.
http://www.mediafire.com/file/jm3bw49mjodn96h/mb_MusicScheduler_2017-03-03.zip
still to do: support Auto-DJ along with playlists in tasks.
various improvements and bugfixes:
http://www.mediafire.com/file/l5ufxv2vys5y6ki/mb_MusicScheduler_2017-03-07.zip
NOTE: in case of upgrading plugin from version 1.0 delete all scheduled tasks and recreate them from scratch.
theG
Decided to try it again and when I press Apply/OK, MusicBee freezes, I have to kill it. Using latest 3.1 patch.
have you deleted all scheduled tasks from previous plugin version (1.0)?
allavaz
For some reason Auto-DJ doesn't work for me. When I set it to a playlist it works fine but for Auto-DJ it doesn't do anything. Any idea?
yes, there is some bug. sometimes auto-dj works, sometimes doesn't for me. will try to fix this bug.
allavaz
Thanks a lot man it's working now. Another thing I noticed is that clicking on OK or Apply stops playback. Is that on purpose?
i don't remember. probably thats intentional.
Rotary
This Plug in is super useful !
However I encounter several hiccups using
Basically, I have 5 playlists that need to start at different hour during the day, everyday.
When the computer in plug off the task stop so the next playlist is not playing or it stops after 2 days, is there a way to configure it to run on battery as well and to remove the time limit?
I tried to modify the task directly, but it doesn't launch the music afterwards and when you click on apply again, it reset the task to the default settings.
Can the VB files be modified to change the settings in the windows task scheduler?
Thank you for your time
plugin uses windows task scheduler if you tick 'wake up computer to play this task' option (dont remember exact wording, its option in the table).
2 day limit is intational and it would be very hard to change this.
i think i didnt understand the problem with running notebook from battery.
