Author Topic: Plugin - How to get the selected file? (Playing / Selected)  (Read 3250 times)
mless
Hello,
With NowPlayingList_GetFileProperty I can get information about the currently playing file. I'd like to determine what file(s) is currently selected. Is there a function to do this? Like when the "Playing / Selected" button in the Track Information panel is set to "Selected"?
Thanks!
i suggest you have a look at the Advanced Tagging Tools plugin as it has functionality to get the selected track. The API implementation for that is a bit of a hack though.
You need to query using Library_QueryFilesEx("domain=SelectedFiles",files-urls)
